Welllll I just saw squizza old cefiro, 3 streets from my house, and then just down at 'da plaza' I saw SHY 32, but I liked it better with the black stockos on it, not the chrome :). Crazy I say whats going on with browns plains! cause there is a nice R33 GTR just up the road too... and a bright green R34 sedan.
white 33 gts-t with blue calipers on the story bridge about 12:15pm today, must be someone from here.
midnight purple 33 gtr near muarrie/park hill at about 1:30pm today, looked and sounded pretty sweet.
Yeah that was me in the white 33. were you in the grey 32? I looked at you to wave but you wernt looking, i was taking it heaps easy as my tyres were like slicks and it was raining.
Ok, i just thought this was real strange, on my home i passed 3 skylines all purple (deep dark) all r33's as well. The first was on Oxford St then i saw the other two on Wynumn Rd in Tingalpa, it really freaked me out as they all looked identical, anyone from here?
Was the 32 heading toward or away from the city? im goin over that bridge bout that time mon to thurs
Hi people,
well its been a long time comming but i have finally got my 33 on the road (been stuffing around for a while) It be black and lookin VERY stocko ATM except for exhaust and air filter. I have a side mount number plate and a rather large wing (for a standard effort) with a lil round LED brake light in the middle....SEEN ME YET?? Around Brisbane's western suburbs...toowong, milton, bardon, st lucia, rosalie, etc etc etc....
give me a wave.... :)
HAro
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
