Welllll I just saw squizza old cefiro, 3 streets from my house, and then just down at 'da plaza' I saw SHY 32, but I liked it better with the black stockos on it, not the chrome :). Crazy I say whats going on with browns plains! cause there is a nice R33 GTR just up the road too... and a bright green R34 sedan.
white 33 gts-t with blue calipers on the story bridge about 12:15pm today, must be someone from here.
midnight purple 33 gtr near muarrie/park hill at about 1:30pm today, looked and sounded pretty sweet.
Yeah that was me in the white 33. were you in the grey 32? I looked at you to wave but you wernt looking, i was taking it heaps easy as my tyres were like slicks and it was raining.
Ok, i just thought this was real strange, on my home i passed 3 skylines all purple (deep dark) all r33's as well. The first was on Oxford St then i saw the other two on Wynumn Rd in Tingalpa, it really freaked me out as they all looked identical, anyone from here?
Was the 32 heading toward or away from the city? im goin over that bridge bout that time mon to thurs
Hi people,
well its been a long time comming but i have finally got my 33 on the road (been stuffing around for a while) It be black and lookin VERY stocko ATM except for exhaust and air filter. I have a side mount number plate and a rather large wing (for a standard effort) with a lil round LED brake light in the middle....SEEN ME YET?? Around Brisbane's western suburbs...toowong, milton, bardon, st lucia, rosalie, etc etc etc....
give me a wave.... :)
HAro
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
