white 32 gtst with white tri spoke mags, tinted windows and a loud f*ck off exhaust - sounded like a straight thru with no cat or muffler. Down the coast on sat nite at the carpark and also leaving surfers heading southbound along GC hwy.
Saw a nice 34 GTR on park road last week too. Was white vspec no. plates NVS 677 (envious 6 twin turbo)
