The only one I know about and can recommend (because I've used them) is Wheel Repair Centre, 8 Pioneer ave Thornleigh, 02 99801125.
Did a good job of repairing my cracked rim.. Done a few track days on it since and it's held up perfectly.
https://www.sau.com.au/forums/topic/192729-rim-repair/#findComment-3462108
What did it cost?
https://www.sau.com.au/forums/topic/192729-rim-repair/#findComment-3462148
Best place for a rimjob (so ive heard) is Mag Man, never used him though so not sure if its a good job or not
Ive got 4 wheels that need a recoating, Jon what exactly was done to yours? I want mine sandblasted then sprayed black and lip polished
https://www.sau.com.au/forums/topic/192729-rim-repair/#findComment-3462203
I've heard you can get a good rimjob from a place in Kings Cross too!
I had a crack that went all the way through the outer part of the rim. It released air very quickly, so it was a fairly large crack. They welded it up, and filed it back. It wasnt a particularly flashy finish on the rim - just a matte aluminium, so they just polished it up and it came out looking good as new. There was weld marks on the inside of the rim where they didnt clean it up as nicely, but it was obviously like that because it isnt visible..
I cant comment on their finishes as mine wasnt really all that difficult.. but from the quality of the work that i saw I would recommend them.
https://www.sau.com.au/forums/topic/192729-rim-repair/#findComment-3462246
the one from '241' just doesn't cut it, eh?
Nah, she's getting a bit old - its been a few months, time for someone new
I just picked up 2 of my cracked rims from Magman, $85 each.
Damn thats cheap! Did he just fix the crack or fix and recoat?
https://www.sau.com.au/forums/topic/192729-rim-repair/#findComment-3463570
He rewelded and built up the cracked area, turned down on a lathe, applied some inner compound to aid sealing
and refitted tyre, although he didn't balance but no biggie. Nice job for little money. Both of my rims had inner cracks,
so no worries about finish, although he does refurbish completely. Many on the aus300zx forum have used him over the years.
https://www.sau.com.au/forums/topic/192729-rim-repair/#findComment-3463804
gday fellas
need a rim fixed. put a scratch on it when i went to close to a gutter.
can you recommend places north shore, drummoyne, inner west, city??
cheers, MARK
the guy at chippo is the best he does morton and may's big damaged stuff; iknow this for fact
as i work for PRO-DUCT motorsports and have used both guy's.
the guy at chippo has fix every one of mine so far his the s...t and fair on priced!!!!!!
cheers tom
https://www.sau.com.au/forums/topic/192729-rim-repair/#findComment-3470249
  • 9 months later...
I'd recommend the guys at Thornleigh as well. I've used them twice and both times they've done an exceptional job. Fair price for the work they do. They also manage to perfectly match the unique bronze colour of my wheels, which impressed me!
https://www.sau.com.au/forums/topic/192729-rim-repair/#findComment-4089773
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
