  • Replies 96
Posted Images
Remote is all sorted now with much thanks to /2on, just wondering, for ppl who have installed this and got it working, do you have to mount to eji unit flat and level, im assuming so as it has a g-meter in it and i doubt it will work if i mount it vertical, unless i roll which i dont plan on doing.
Ask nightcrawler or michael their the only 2 people i know who have or had these.
Ps i just noticed your car looks almost identical to mine asides the rims and now we both have the same dash......scary :P
Edited by /2on
Now i have yet another problem, i put the dash in today, all went well apart from the speedo now says i am doing a little over half the speed im actually doing, i removed my avcr display when i put the dash in which i know was only 2k's out, so i plugged it back in to check the speed and now my avcr is doing the exact same thing.
The only thing i can think that i did wrong was when i wired it up one of the wires i hooked into was not the actuall wire off the ecu, there was a wire coming off the ecu wiring going to the avcr so it was easier to just use the avcr wire to tap into, im not even sure if it was actually the speedo wire that i did it with, any idea if this could be the problem, or any other ideas what it could be?
Found another Option to the EJ1 and HKS Camp, Blitz have released their R-VIT DS which connects to a display
Looks good, but from what i can find it seems to run off the ODBII port, which i know 33's dont have.
lol!
yes they are pretty cool ;) its a limited edition nismo dash with the option of sat-nav or epson ej-1 driving emotion system. they are extremely rare, they come up on yahoo-auction very rarely, and the dash normally sell upwards of 60,000yen and then you need to find the epson ej-1 system which can sell upwards of 40,000yen
the epson ej-1 system display information like, speed, rpm, g-force, power, torque, lap time, fuel eco etc etc
here some photo of mine
and some details on all the info it can display
thats awsome I think nismo makes ones for the gts-t as well.
  • 10 months later...
I have an Epson EJ-1 computer system for sale if anyone is still interested. Full setup, everything you need, includes remote, wire diagram charts and installs in a matter of 30 min. by tapping 6 wires on your ecu. Any ecu compatible, I am running Power FC on my 33 GTR. This will work with many, many motors. The list is in the instructions. I sold my GTR and took this out cuz I loved this gadget. Displays to ANY monitor with rca video in, doesn't require and does not include the Nismo lcd cluster. Located in the US, will ship world wide once confirmed payment of $450 usd Any questions, please email [email protected]
http://picasaweb.google.com/lh/photo/KvTlh...feat=directlink
http://picasaweb.google.com/lh/photo/l7TK2...feat=directlink
  • 2 months later...
old thread...but i love my EJ1+nismo dash hahaha
one problem though, everything seems to work OTHER THAN g-force screen and speed screen which shows nothing. ontop of the speed screen not working, my odometer is not clocking over, but the speedo and tacho works fine :S help?
  • 1 month later...
SOLD
im sure this question has already been asked but would one of these fit and work in an r32 gtst at all? ive never heard of these things until tonight, they look pretty kool
Obviously the dash its self would not fit but the ej1 may work, it has jumper settings on it for different engines so it may work with a 32, the output is just an rca so it will hook up to any aux input on an in dash screen.
  • 3 months later...
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
