How Much For Blue Slips?
Issues? More like they if they were the only manifold on earth, I would rather go drown in a pool of dogshit They were proven to be crap at everything.. chokes, makes far less power then 6boost, and is just something that deserves to be in the bin.
This is awesome! I'm looking forward to seeing updates. Welcome to SAU!
Cranking usually single digits, once it comes to life there are a few tables that layer ontop of each other. This is the 0 throttle table Then post start table Then coolant table Let's say the water temp is 10 degrees C, you would see in the first 2 to 3 seconds about 33 of timing. Not to mention, the idle strategy would also throw more timing at it if needed -
Anyone able to tell me what the ignition timing at "start" is for a RB25DET. I am using a Wolf ECU, and I need to set at least 35deg for the engine to start cold.
