Hey guys,
I have the autosalon semi's this weekend...so thought I would post up some pics of the event for you all to see...
Well...they will be up soon. Dropped the car off tonight and will update with pics of dyno comp, cars etc...
....pics to come ;)
https://www.sau.com.au/forums/topic/192976-autosalon-semi-finals/
700+kw is incredible, any video of the run ?
Nah i didn't get a vid of it...only a vid of the ESP supra. Here is link to the supra run:
Have a look on you tube and search for 'RH9'. There are quite a few of it from last year running over 1000awhp.
Someone buy this man a better camera! or are the photos of the chicks blurry because your hand is also down your pants?:)
Some nice rides though if I look past the rice.. and some nice power :rofl:
haha it is a bit difficult to quickly take a shot while they are not moving and people are walking through. Point...click...oops forgot to focus :blush:
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
