here gos
ill say how it was installed and what bits stage by stage
deck is a rockford fosgate rfx8220 with triple preout front/rear/sub
all custom thick neotech RCA's ran straight down the middle console to the boot
mbquart DSD216 splits in the doors
made brackets to hold the midbass and placed the tweeter on the plastic bit that hides the wires going to the side mirrors then covered it with cloth (cant see them basically)
mbquart 2 ways in the rear where the factorys went but on top and the "active speaker" grill gone also all speakers had thick neotech cabling down each side of the car
in the boot where the metal wall is from the back seats to the boot was taken out and a MDF cut to size board carpeted was placed in there and 2 kenwood amps mounted on it (749s 4x40rms and 1x250rms 719 monoblock) (12v 4 ohm)
4 guage cable ran from the battery thru a 60 amp fuse all the way to the back seat then split from a distro block to the 2 amps
all wires came from the back seat and individually had there own hole to screw into the amp so its all nice and neat
sub of choice is the JL audio W3 12" DVC in a 1cft round backed box that faces the rear of the car and fits nicely in the driver side corner with the thick neotech sub cable hidden to the terminals
this all resulted in a bloody good sound
i get around 125dB out of it and its very punchy up front
splits r highpassed at 100 and 2ways at 130
sub low passed at 100
the things im gonna do is
take a couple of rattles out in the back parcel shelf
and in the doors and sheet sound deaden them
its suprising that there isnt many rattles
then once the cash cow comes ill get myself 2 rockford amps(a big 4 chan and a bd1000 monoblock and another JL audio sub (prolly sell mine and get 2x dvc 2 ohm subs cause u cant get 2ohm out of 2 dual 4 subs) and run individual boxeson each side
then put the splits from the front in the rear and get some mbquart premiums
there is no way id have any other brand than mbquart for my speakers
and the raw power of rockford cant be beat
and the quality of bass from the jl cant be beat either
but it all depends what u listen to
also i mite change the deck and if so it will be a eclipse
u guys go check out an eclipse deck they r expensive
but bring a cd that wont play in your cd deck cause of scratches
and it will play flawless in a eclipse
600ish for a high volt eclipse with mp3 and triple rca preout
and stop buying main stream brand name products if u want really good sound! (jvc pioneer clarion kenwood alpine (alpines amps high end splits subs and decks r ok tho) u get what u pay for
also check me car out
www.cardomain.com/id/rthirtytwogtst
https://www.sau.com.au/forums/topic/19319-my-r32-stereo-setup/
dude thats one serious set up, but u really shouldnt post that kinda stuff on forums, it like k-mart for prospective car thieves, i would be devistated if someone stole nething outa my car. also be careful, most insurance companies will void ur policy if they find out u have big $$$ audio system as it makes the car hot property for theft.
Just my 2 cents
I love my setup, its cheap as chips and goes sweet as, i think the general size of an r32 really helps sound quality, i desperately need some good front splits, i found that 6.5" are near imposible to fit...the hard way(bought them), good thing they were home brand, i am now thinking in the direction of 4" fusion powerplant fully crossed components for the front.....easy fit no messing around, as for removing the metal out of the back seay, you got more patience than me, i drilled clean into it for my amp lol.....
yeah i like the solo barics for the hard punch and the looks
not too fond of the kicker splits tho
and cereal what do u mean by how do i power it
a monoblock is a single channel amp
if u run subs u have a monoblock its as simple as that
or either a big 2 channel
but mono is better because then 2DVC 4ohm subs can run at 2 ohm
its getting about 250-300wrms and is lovin it
I'm wondering what powers your DVC sub? because it requires 2 channels to be powered correctly.
you have a monoblock amp which is usually meant for a single voice coil sub - hence you cannot power a DVC sub off ONE monoblock amp: you'd need 2 monoblock amps to power a DVC sub (which would absolutely sound awesome.)
ahahah
i can see your a noob and its ok :(
ok now most subs r 4 ohm's
u can get dual 2 ohm subs
and it all depends on how many subs your running to what ohm subs u get
because all car stereo amps r 4 ohm
and 2ohm when bridged
a single DVC 4 ohm will give u 2 types of ohmage when wired different series/parallel
i dont know whats called what
but the combos u can get with a single dvc 4ohm is 2ohm or 8 ohm
2 dvc 4 ohms is 1 or 4 i think
2 dvc 2ohms is 2 or 8
single 2ohm is 1 or 4 i think
now doing what u said
getting a 2 chan amp
then powered both sides
its then basically getting a left and right signal and thats bad
most 2 chan amps have a switch saying stereo or mono
and if u were to use the 2 chan u'd put it mono for both channels
but why when the amps channels will be both running at 4 ohm
then bridging a 2 channel amp for 1 chan makes the amp go 2 ohm and then puting a dvc 4ohm sub on it would pull a .5 ohm load which would blow the amp or it would make it 4ohm that would half the power and basically make that bridging useless
a 2 chan amp bridged with a dvc 2 ohm sub would be good cause u can get the 2ohm load then when wired properly
but whoever told u this is full of shit
lower ohms = more power
my amp is sumthin like 150x1 at 12v 4 ohms
or its 300x1 at 12v at 2 ohms
bass isnt a left right signal
the bass is the same in the left and the right i think
but the monoblock processes all that its got a left right plugin from the subwoofer preout on your deck (if u got a triple preout deck)
www.jlaudio.com
go there and dl the fact sheets for the jl w3
it shows wiring and box specs
just get any pdf on the product page of the w3 sub and it will show u wirings of dvc 2 4 and 6 ohm subs
Well i guess my dual DVC powered off my single bridged amp should be falling over right about now. Its not, works quite nicely actually - its not even a powerful amp :)
As above (I think), but that guy needs to use formatting 'cause its too much effort to read :(
Anyway, keep reading - you learn lots via reading forums !
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
