Manual or Semi-auto
23 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hi guys,
Thank you all for voting in my previous thread on selecting the right car.
I have made up my mind on the Evo 10.
Initially, I would have wanted a manual.
However, my parents want me to get the semi-auto. They think its better to drive and will have better resale value.
If you were getting the evo x, which transmission would you get?
Please place your votes above.
Luv u guys.
Dr Dan
Edited by danieltangtc
yeh i think their semi-auto box is like the vws and audis, DSG, you can hardly feel the shifts but its an awsome drive. Id say semi auto but then if you wanted to take it to the track maybe a manual?
edit: good choice on the car btw :P
Edited by vinnie34gtt
its not an auto, its a dgs... ie clutchless manual. when in auto mode it uses shift logic, when in "manual" mode it should not change at all unless you tell it to engage.
google DSG for indepth information.
If it is a road car then the DSG gearbox is far more superior than a manual.
If you plan to track or rally the car then a manual will be a better choice.
Listen to your parents, they are correct and if there is any problem, it has a 5 year warranty.
How do you guys find the DSG transmission in the Audi/VWs?
I have never driven one before.
Also, if I were to sell the evo in future, which would sell better? DSG or 5spd manual?
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
