  • Replies 76
So onto the real reason for stretching your tyres if you are a drifter:
1. 99% of real drifters aren't sponsored, are poor and can barely afford to keep their cars on the road. Wide tyres are out of the question. Find tyres that your local tyre shop or service centre is throwing away (out the back, ask for em) and make them fit the wheel.
but, but- it costs more to buy the wide rims in the first place! they'd be better of just buying narrower rims and fitting the same tyres anyway if it was just a cost issue
Does this pass for a reason to have stretched tyres? :glare:
very impressive co-ordinating of wheel offset, ride-height and tyre stretch....but utterly ludicrous all the same :yes:
here's a couple of examples of where a stretched tyre is practical:
From the US:
From Adelaide:
Here's an example of a "drift style" car with a 4wd ride height
remember kids, stretched tyre and gap between wheel and car or 4WD style ride height = punch in the c**t.
Do it properly or don't do it at all.
I'm sorry to all the 'haters' but that second pic looks bloody awesome. As others have mentioned and as you can see, the stretch can enable you to fit wider rims or rims with lower to negative offsets on your car without having to jack it up to 4wd height or flaring the gaurds. having the stretch for cosmetic reasons is the same reason people choose a certain style of rim (why 5 spoke of seven spoke or mesh style for example) no one can deny that have wide rims makes your car look so much tougher than wheels with massive positive offset sitting so far in the gaurd it looks like an old citroen.
Wow how does that second to last pic get anywhere without scraping the f**k out his rims/tyres.
No scrape whatsoever
Cusco Zero 2 R coilovers on middle damper settings...its all about knowing how to build the guards around the wheels
but then again im sure you are happy with your 17x7 +45's
Simple, It rides so hard the guy is now 3 foot tall from spine compression. ;)
6" actually...but thanks for your concern
Didn't you know? Performance cars are about looks and wank lists rather than performance now.
why bother building drift cars these days that are super competitive? when someone with a $500,000 sponsorship package and no talent will wipe the floor with you...id rather rock my budget spec lookin cool than drop 30K into a car thats gonna be worth 10 in less than a year...youre forgetting ive got an evo for going fast...the soarer is just my "shit car"
and cheers R33silverS2
more pics for the haters:
oh yeah its rediculously low and runs about 4.5 deg of camber at the rear too...get out your pocket protectors and calculators and work out how f**ked that is too
nerds
Edited by coprims
Also btw in regards to the original poster...Bridgestones will often stretch the best as they have nice stiff sidewalls :w00t:
the tyres on the pic of my soarer funky munkey posted are Bridgestone RE040A's (could be 050's)
I'm running 17x9.5 +15 on my 31 :w00t:
Find me another rim for that price in that size that looks half decent.
youre missing my point
you as a purchaser of chinese crappy wheels that becuase they come in a half decent offset and width just like 10,000 other silvia owners have no right to voice any negative opinions at those who make the effort to purchase decent 3 peice wheels and make them fit their car...
I hope this has been edumacational
kthxbi :(
coprims your mad! (in a good way)
haters have completely missed the point of my thread, i wanted to know how stretched you fellas are and what tires you think are best to achive this.
NOT why you are a loser if you stretch, but thanx anyway hahah you fags.
in my op, iv always been a huge fan of wide wheels (who hasnt) and not such a big fan of overly wide guards to fit them, what better way to achieve this???
my wheels are 18x9.5 super advans all round, 215/35 on rear, 235/40 up front. will change em all to 225/40 if i cant find 35 all around once they get shredded.
But they don't fit the car?
f**k me if I was gonna fork out $3k for rims I'd be sure as hell to get them in a width/offset that fits without needing stretched tyres/flared guards.
unless you have to AT A MINIMUM roll the guards on your car then your wheel fitment is not 100% right in my opinion
But thats because you are a fully sick drifter with ghetto stretched tyres, I want my car to handle properly and not chew out my guards, I also don't want to be defected. :yes:
you dont have to have stretch and massive camber for good fitment
put up a picture of your car so I can have a look...
also I dont know whats so hard for you to understand that my car does not scrub
front or rear dont scrub at all...on suspension compression ive got somewhere for the tyre + wheel to go in the guard...
it wouldnt be perfect if it didnt...
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
