  • Replies 57
go for a drive through your local industrial area.
for e.g i worked for a mob who made home & office furniture in which they had their own powder coating oven/facilities. BUT obviously didnt advertise as POWDER COATERS.
Slip the foreman some cash. Bob's your Uncle.
Too bad your not closer(Sydney),my old work does it for $7 per hanger probly double per rim cause they are quite big.
if they make steel or ally furniture good chance they powdercoat it themselves or can put you in contact with who they use for their powdercoating.
and its not just colours you can choose from,you can get ripple effects and all sorts of cool finishes.
Happy Hunting!
hey guys,
new info....
u guys who had powder coated ur rims in ALLIANCE....
they don do it.... they have the guy beside their place to do it for them....
nothing special but just letting u know.
  • 3 weeks later...
*UPDATED*
I have already so called powder coated my rims. for $50 a rim. Brought it to the shop tat was reccomended. and talk to the owner about it n he said yes he can do it in a few hours as he is powdercoating some stuff which is using the same colour (matt black). assuming that he is a good trader, i happily i left my brand new set of rim with him. was told to call back after 3 hours, i did! He says come n pick it up its all done! WOW tat was quick! check the rims, everything look fine, paint was even, no stratches. Paid him n left. Planning the next thing to do - get some rubber n put it into the car!
Went to the tyre shop, showed the guys there my rims. AND was told tat my rims were sprayed with matt black not powdercoated..... how did they know???? one of the rim was not painted inside as they can see the originaly colour. i was shocked! they tyre shop guys said i was ripped off!!!!!!!!!
WTF!!!! OMFG!!!!! SHITS in Pants abit....
Dont think i can put the company name here but if u want to know just pm me b4 u fall into the same trap!!!!!!
SHitty trader sucks!!!!!!!!!!! :P:laugh:
*UPDATED*
SHitty trader sucks!!!!!!!!!!! :D:)
Dam that sucks . . are you sure it wasnt poder coated? Maybe they just did a shitty light job and it didnt cover the whole rim . .
I used to build aliminium products and we used to powder coat. Sometimes with different colours in can look that way.
My guess is your tyre shop did not know what he was looking at. just my opinion
Hopefully it was powder coated, i know some powdercoaters sprays using an electrostatic gun(not sure wat tis is). but i will be posting some pics for u guys to see....
No point calling them back. complaining to them would just be a waste of time. just consider my self bad luck!!
I am just trying to help other car owners from falling into the same trap thats all.
if i would be bringing the rims back to them or another shop, they might just charge me more. strip them current paint to the orignal colour , sand blast the rims and then powder coat it back again. so i reckon it will cost me another 200 to 300 more....
Edited by lcy
have you called the business to complain yet?
i am going to call them now....
there are many pics of the imperfection.... but some are just too diff to see from the pics....
****EDITED****
Do not post clues to show which business it is. Grow up.
i dont mean to give clues... just saying tat i did a research n they poped up as a sponsor, so anyone would think they are doing a good job tats y ppl are asking them to powder coat their stuff tats all.....
put urself in my shoes, wat if it was u getting ripped off. maybe tat doesnt happen to u but tat wasnt my intention to give their company name out. if i wanted, i would just WRITE IT HERE till i get banned.....
SORRY!
Edited by lcy
GUESS WHAT!!!!
just gave them a call n talk to the manager. got flamed back.... n he put the phone down not even wanting to explain.....
so guys wat should i do?!!?!?!?
anyone who know about powder coating don mind helping me out n going wit me to see him??
f*ck the manager that i talk to. so f*cking rude!!!!!
GUESS WHAT!!!!
how did the conversation go? were you polite? :dry:
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
