Hi Peoples,
I am cleaning out my shed and i have a few assorted parts to clear, i am open to offers just PM me.
will post at buyers expense.
Item: Std R33 GTS-T blinkers from front bumper with plugs
Age: 12 years
Condition: Good, i changed them to suit my new bar
Price: $50.00
Item: Std R33 GTS-T Grill M-Spec i think? It has the S in it, see pic below. Much nicer than the letter box grill.
Age: 12 years
Condition: Good
Price: SOLD
Item: Std R33 GTS-T water pump
Age: 12 years, looks as if it was replaced just before i got the car
Condition: Good, was running perfect
Price: $30.00
Item: Std R33 GTS-T top half of inlet manifold
Age: 12 years
Price: $10.00
Item: Std R33 GTS-T turbo inlet hose
Age: 12 years
Price: $20.00
Item: Std R33 GTS-T rear brakes, rotors and brake lines
Age: 12 years
Condition: Good, were operating great but rotors will need a skim now
Price: $150.00
Item: RB30 short block, dissasembled
Age: ?
Condition: Good. bores are ok would need to be bored out to square them up crank needs some speedy sleeves, pistons and rods look ok.
Price: $100.00
Item: ARP main stud kit for RB30
Age: new, in box.
Condition: new, one stud was installed and found out they did not need them,so there are some small marks from removal
Price: $140.00
Item: Greddy copy plumb back bov
Age: new
Condition: new still in box
Price: $100.00 now $80.00
:P
https://www.sau.com.au/forums/topic/193846-assorted-parts-rb25s-and-rb30s/
  • Replies 42
hi mate... send you a pm couple of days ago.. still no reply...
anyways im interested in the turbo, exhaust manifold, injectors, fuel pump, cheers let me know on price... il take most of the stuff
I am sorry mate i have just finished my panel of 12hr night shifts, so i have not had the mental capacity to get some photos organised for you. But after a little nap i will get cracking on them today. I will PM you this afternoon.
Cheers,
Ryan
    • They’re so great that I know of someone pulling one out to go back to a sequential
    • Hello everyone. I've recently started the research into R34 GTR front bits and running into eye watering prices. On the plus site it looks like some places make 'replacement' fender liners for these cars. At eye-watering-but-less than stock prices. I also noticed there's plenty of diffuser options available too. What I would like to know is if my following assumptions are correct. 1) The OEM guard liners are actually only 'half' the liner. They go together with the OEM brake vents which are a separate item which looks to be quite a large 'panel' that is part of the liner. The GTR bumper has bolt holes along the front. I assume the ones in the vent correspond to the ones the OEM liner does not have (circled?)   2) The V-Spec front diffuser supplants the brake ducts in the above item. I am assuming these still work with the guard liners as there's no alternate part that I'm aware of. I don't see how they go together, so I'm making the assumption that they have to, somehow. I know the center splash guard is different on the V-Spec (and is the price of the damn diffuser alone). How does the liner interact with this? 3) There's alternate front diffusers that do away with it all. Annoyingly, a lot of the clones and CF different ones... have no brake ducts on them. I like the idea of them though. My brakes get hot on the track. These alternate diffusers are a lot cheaper than plastic splash guards. I'm assuming you don't have to/aren't supposed to remove guard liners to run a diffuser. I suspect that quite a few people actually do not run the guard liner because with a front undertray you're getting a lot of 'splash' guarding anyway, and most people remove liners given they're probably running a pretty aggressive setup with a diffuser at the front. It would also be nice to know if anyone has ever run the 'reproduction' guard liners and know whether the fitment is OEM quality or "OEM Quality". Example: https://www.ebay.com.au/itm/356254671561 https://carbonetics.net/products/nissan-skyline-r34-gtr-plastic-front-wheel-arch-set Is this knowledge still around?
    • Really, effort is pretty low. You hand fistfuls of cash over to someone else and pick it up when done...   And at least this shitbox isn't drinking coolant right?
    • And most chargers that most DIY people own would put bugger all power back into the battery between cylinders. I've always done it with jumper packs/second battery connected. And that's on any car.   Because race car, and wanting the lightness.  At least in an R33, putting a bigger battery in can at least help shift the weight balance backwards
    • OR, Tell the Motec to STFU, you said shift, so try shifting! But then yes, I agree, more sensors needed to. Put either a wheel speed sensor, or a diff speed sensor on it. Then get an input shaft speed sensor too. (I say input shaft speed, and not engine RPM). This way, you can now also log and see if the clutch is slipping (RPM, vs input shaft speed), and you can calculate gear (Input shaft speed / Output shaft speed). At least then if the gear position sensor fails you have a backup. And realistically, the Motec should only worry about what gear you're in for the parts where I'm assuming you have some power management strategies in it for the lower gears. (IE, lower boost, maybe different throttle curves, different ignition curves, etc etc). But it should stop it shifting. Pull the flappy, that f**ker should just attempt the motion! Heck, even on a sequential like on a motorbike, you can keep trying to kick it up a gear all you want, the physically part of the box takes care of not being able to loop the whole way around the box! Only part you'd have to worry is how it gets to reverse.  But that's on the driver... An R32 shouldn't be so smart as to try and override the driver on a gear shift
