Hi Peoples,
I am cleaning out my shed and i have a few assorted parts to clear, i am open to offers just PM me.
will post at buyers expense.
Item: Std R33 GTS-T blinkers from front bumper with plugs
Age: 12 years
Condition: Good, i changed them to suit my new bar
Price: $50.00
Item: Std R33 GTS-T Grill M-Spec i think? It has the S in it, see pic below. Much nicer than the letter box grill.
Age: 12 years
Condition: Good
Price: SOLD
Item: Std R33 GTS-T water pump
Age: 12 years, looks as if it was replaced just before i got the car
Condition: Good, was running perfect
Price: $30.00
Item: Std R33 GTS-T top half of inlet manifold
Age: 12 years
Price: $10.00
Item: Std R33 GTS-T turbo inlet hose
Age: 12 years
Price: $20.00
Item: Std R33 GTS-T rear brakes, rotors and brake lines
Age: 12 years
Condition: Good, were operating great but rotors will need a skim now
Price: $150.00
Item: RB30 short block, dissasembled
Age: ?
Condition: Good. bores are ok would need to be bored out to square them up crank needs some speedy sleeves, pistons and rods look ok.
Price: $100.00
Item: ARP main stud kit for RB30
Age: new, in box.
Condition: new, one stud was installed and found out they did not need them,so there are some small marks from removal
Price: $140.00
Item: Greddy copy plumb back bov
Age: new
Condition: new still in box
Price: $100.00 now $80.00
:P
https://www.sau.com.au/forums/topic/193846-assorted-parts-rb25s-and-rb30s/
  • Replies 42
hi mate... send you a pm couple of days ago.. still no reply...
anyways im interested in the turbo, exhaust manifold, injectors, fuel pump, cheers let me know on price... il take most of the stuff
I am sorry mate i have just finished my panel of 12hr night shifts, so i have not had the mental capacity to get some photos organised for you. But after a little nap i will get cracking on them today. I will PM you this afternoon.
Cheers,
Ryan
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
