serious hey,what about front bars?
i see heaps of cars minus the front bar getting around.
EDIT: well i guess if you must have a grill,must also have a front bar,but still see a fair few getting around
Edited by RSTME
https://www.sau.com.au/forums/topic/193856-laws-on-bonnets/#findComment-3485666
Headlight is compulsory.. I believe that you only need one high beam tho. so you can run a CAI system with one low beam and parker. Both have to be working too! parkers cannot be blue or red as emergency vehicles hold this colour.
Yes you need a front bar, it is illegal to have any part of the chassis exposed because it is sharp and not smooth cornered. This is a major problem if you hit a ped because a broken leg then turns into a cut in half leg. you get my drift.
Why such strange questions
Oh and front bars cut to expose a intercooler or a intercooler poking out the bottom of a front bar is also a sharp edge, as is a drift wing and so on. all defects.
https://www.sau.com.au/forums/topic/193856-laws-on-bonnets/#findComment-3485709
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
