Group Buy For 6000k Hid Kits! [closed]
GB now closed.
want to get it all organised before the xmas & new year period or else stuff getting delivered will be delayed.
brand new 6000K HID kits to suit H1/H2/H3/H4 (low) & (hi/low - not recommended for 180sx as the solonoid is too big and cuases the lights to not close properly - will fit other H4 type headlights that are non pop up)
this is the only kelvin range available as its the best and widely recommended for street use. so please dont ask if i can get 5000k,8000k etc
comes with 12months warranty from the manufacturer - all kits will be inspected before sending out to ensure they are 100% perfect.
more then 5 ppl to get it at $135 delivered
hi/low H4 is $190 delivered
if less then 5 its $150 per person.
ill have pics up soon of the H3 fitted to my R32.
any enquiries please feel free to either pm me or reply here.
individual orders are ok so 1 person interested only can still order at $150 delivered :ph34r:
i will require all payments to be made up front so i can place the order on the 30/11/07 so i can get the order in. delivery will take 7-10 working days via AUSPOST. if anyone is worried about scamming or security issues, i can give you my full details (address,homephone,licence #) etc. once ive placed the order, it will take 5-7 working days to get to me then 2-3 working days to get to you depending on where you live (express is next day and will cost $7 ontop).
postage method is registered post for each box with tracking # and insurance.
also guys, after you have received your HIDs, please leave me a trader rating/feedback and i will do the same ;)
cheers
1. N1GTR - H3 PAID
2. Yogi001 - H3 PAID
3. (B1) Mr Fanny - H1 PAID
4.
5.
update 5/12/07
hey fellas, ive placed the order just then so it should be processed and delivered to me with 7-10days and then out you guys ASAP via registered post with insurance..
was waiting for krisG to make payment as he promised mon or tues morning and it is now wed and nothing has shown up so he is out of the group buy
cheers.
Edited by whyte
https://www.sau.com.au/forums/topic/193986-group-buy-for-6000k-hid-kits-closed/
  • Replies 59
is it a simple plug n play for 33's? dont want to hack into the housing or anything.
i assume i will have to take up warranty issues with the hk dealer directly and not you?
with the hi/low setup i assume that they are both on instead of switching from low to hi?
cheers.
warranty can come back to me and ill get it sent back but like all warratny issues, buyer pays for all delivery costs.
what bulb size does R33 use? i think its H1 and if it is, they dont have a hi/lo in that ublb size champ.
pm sent zimmi!
Ill take a set for R32 GTR thanks ;)
32GTR has a h1 light bulb sitting on an adaptor which is H4....
some1 told me that i will need to modify the adaptor to fit the HID
correct me if i'm wrong.....otherwise i would love to get 1 set for my 32R
Ill take a set for R32 GTR thanks :(
im not sure about this guys, arent they same as gtst?lol my one uses H3C but H3 fits them all.
can you guys confirm what bulb type needed to fit your car :domokun:
N1GTR pm sent!
can you guys confirm what bulb type needed to fit your car :glare:
N1GTR pm sent!
nah....its different from GTST......
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
