Me :D
Driving up to the Terrigal going up the Mooney Mooney Bridge and then a little pop then no boost. Hooray no turbo.
I've always said the exhaust needs to be a bit louder and today I got my wish.
For all you people who are running R33/34 turbo's dont run more than 11psi cause that was all that was needed to knock the bastard off.
Alright time for suggestions. My budget is around the $1200 mark.
https://www.sau.com.au/forums/topic/19399-guess-who-has-no-exhaust-wheel/
:Owned:
And I think it was more the kms on the turbo, and not the boost level that caused the exhaust wheel to come off. I ran 1 bar on my R33 GTS-t turbo for more than a year with no problems.
Originally posted by Steve
There is a guy in the for sales selling a VG30 high flow for about $370, might be worth a look.
As for a blower, where would you fit it?
That was me, the VG30 is sold. It should put out 15kw or so more than the rb25 turbo. I am having my turbo rebuilt at the mo. It already had a compressor that was slightly bigger than the VG30 and a rb25 turbine and housing, it already made 225rwkw. I am having it rebuilt with a VG30 turbine and housing. I am chasing slightly better top end.
damn...
not good to hear, and at only 11, well at least you got 20K out of it
im still going to keep using my 11 low and 13 high boost settings
(r34 turbo) :uh-huh: , cause im really not impressed with it until after 10psi (how quickly mods feel slow after you get use to them!)
i'll start my hks2530 turbo fund now :D
  • 1 month later...
Well, to my amazement I decided to have a little sniff around the turbo last week and after taking off the heat sheilds discovered that the bloody wastegate control arm detached itself from the wastegate flap. Phew saved me a few hunge and alot of buggerising around.
Only problem now is that the gasket between the turbo and manifold is busted. If its not one thing its another!!!!
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
