i've been whoring the search tool on this forum and i still cant work out an answer.
very rarely the engine check light will come on, and when it does the knock sensor on the pfc reads pretty high. last night drove the car on a cruise for like 2.5hrs and knock sensor read 126 once. @ 4600rpm
during the night only saw it ever got to 40 @ one stage.
thing is i havent hear the engine ping inside the cabin.
some of the boys reckon i was shooting flames last night but thats just fuel dumping right when changing gears?
the car tuned @ racepace last year, and recently was retune there last month. b4 and after its pretty much the same, knock goes off rarely.
mods are TB 3" high flow cat, pod, cooler, 12psi, pfc and walbro fuelpump which is only 3 weeks old.
i'm thinking to get some splitfire coils, anyone got any thoughts?
Edited by eddieeeee-ro
https://www.sau.com.au/forums/topic/194037-pfc-knocking/
if you are not experieicning any pinging, you dont have a plug/coil problem so i woundnt suggest you get splitfires. Knock is really to do with the tune, so your tuner should be able to sort it out for you.
Recieved PM: no probs ;)
https://www.sau.com.au/forums/topic/194037-pfc-knocking/#findComment-3480321
i was of the belief that since he is not experiencing any detonoation, its merely the pfc knock sensor. ie, something to do with the tune? my bad then
probably is the tune i.e ignition timing advanced too much.
https://www.sau.com.au/forums/topic/194037-pfc-knocking/#findComment-3480363
The knock readings on the PFC may or may not be actual engine knock. Sometimes a noise in the engine bay at whatever frequency the knock sensors are set to pick up will set them off. Regardless, the terms "pinging" and "knocking" are both detonation.
https://www.sau.com.au/forums/topic/194037-pfc-knocking/#findComment-3480371
Just go back to Benno with that info mate.
If you tell him 4600rpm, what gear and roughly what load, it'll be one cell that needs adjusting and it wont take long
Also your more likely to notice the one cell at night, as the air is colder. Mine was similar ages ago.
Hit about 80 on a super cold night only around 6000rpm in 3rd, one/two cells changed and happy days ;)
https://www.sau.com.au/forums/topic/194037-pfc-knocking/#findComment-3480472
Ive had my car tuned a few times,as mods were added.My car sometimes shows knock of 80 for a split second at high boost and RPM.
Taken the car back a few times to sort it out.But i was told all is normal.Could be a number of things in the engine bay making noise.
I never hear any pinging but i do get a read of 80 at high loads on occasion.
Tuner is very reputable.And works mostly on Nissans.
https://www.sau.com.au/forums/topic/194037-pfc-knocking/#findComment-3481134
I been having same issue, Due to heat. + more boost. + advanced Timing. from the Manual 120(ish) knock indicates Detonation. In agreement with R21Nizmaid, tuner should be able to fix by adjusting the problem cells.. (which I really gotta get done :S).
https://www.sau.com.au/forums/topic/194037-pfc-knocking/#findComment-3484686
a power fc reading of 125 is false, if it was correct you would definately hear it even if you didnt know what knock is. The knock sensor has picked something else up and like explained above there are many things that create the "frequency" that the knock sensor is tuned to detect, even rocks/pebbles being flung up into the engine bay can set this off.
If you are driving around with the normal max knock sensor of 40 thats ok. Anything around a true knock reading of 80 or so and knocking or pinging whatever you like to call is audible. You'll know when it pings, its a very distint noise.
To make yourself sleep a bit easier, stick it on the dyno and get a pull done just to double check afr's and knock levels
cheers
https://www.sau.com.au/forums/topic/194037-pfc-knocking/#findComment-3484834
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
