the smaller pods you might be able to do away with but if you prefer to retain the sheild go for an apexi highflow panel or the likes, if you want the pod make a custom box or there is one you can buy that is direct fit and replacement for pod filter use. 02 sensor shouldnt be a problem to do esp if you have existing standard dump on there pretty easy. anyone can do it....
Get rid of the standard box but keep the snorkel, get one of these pod box's from one of the guys of here, or there is sum1 else who makes carbon fibre ones
I have looked everywhere for one of these. The guy here on SAU that was getting them bailed and wont do them anymore...Can anyone get one or make one for the 34???? I'll pay good money...
I believe Mr Fineline may have one for sale if you ask nicely :(
give me ur car some money for an afternoon and ill make one.. looks like .6-1mm sheet aluminum and a perspex sheet.. gosh $35-50 worth of parts ther.
i made a quick one for mine yesterday with a $26 .6mm rppled aluminum sheet and some 90degree brackets. no clear perspex sheet.
looks fine. does the job and is legal now :glare: should have used polished sheets instead of the ripple sheet but the ripple sheet has more rigidity
Im tellin ya contact vish
g
I asked Vish ages ago and he said he bought his online somewhere...didnt tell me where though :glare: said look around SAU...I did...and the buy who was getting them made through a group buy quite harshly told me to get stuffed and dont bother asking him to make anymore :yes:.....
Jeez.
Edited by SunnyCoast
Do you have a FMIC???
You could do what i did and mount the afm to the body and put the pod in the front bar where the stock IC used to be...
It will create it own Cold air induction from the original hole in the front bar and its separated from the hot engine compartment...
It works really well, and creates quite a loud induction noise out side the car...
I don't have a fmic yet, but it's def on the cards.
As for the pod and box/shield, can a few of you post some pics up of the different set up's you have regarding your arrangements in that part of the engine bay?
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
