Just a list of some parts I want to sell off. Have started many projects but finished none, so have hoarded alot of parts that I might use "one day".... if that day ever comes.
Parts are located in Sydney, if you want specific pics just let me know.
Electronics
HKS ETC + EDA to suit R33 - $800
AEM Universal race ECU with loom, digital readout (minidash) ECU is new, loom has been trial fitted but not cut $3000
Haltech E11V2 with small flying lead, used $1350sold
AEM 8 channel CDI, version 2 new in box $700
MSD univeral crank trigger kit $300
MSD DIS-4 new in box $450
MSD DIS-4 HO new in box $550
Turbo
Turbonetics 101mm ball bearing, ~1900hp was backup turbo little use $3000
Turbonetics 88mm ball bearing,~1500hp brand new custom thumper unit $3500
Innovative turbo 80mm,~1150hp plain bearing backup unit 5 mins use $2000
Twin RB26 or 2JZ turbo kit, HKS(RB) or Blitz(JZ) manifolds, twin type C trust gates, new catridge 3040 cores w/GT35R comp wheel, HKS 0.87 and 1.12 exh housings, 2 sets of wastegate springs, stainless custom dumps pipes for RB, just got comp covers mirror polished $6000 ono
HKS RB25 exh manifold, HKS gate, HKS 3240 (blown rear seal, rebuild for under $1k or new catridge $1300) $2000 ono
Trust RB26 T4 flanged manifold $1200
Turbonetics T66 turbo needs rebuild, have got new center water cooled housing (orig one had crack on oil outlet hence why needed rebuild) and new Garrett 67mm comp wheel $600
Stock R33 RB26 GTR turbos $400 pair
Trust twin inlet pipe to suit single conversion on RB26, 80mm afm tubes new $120sold
Turbonetics ASME bell mouth suit 100mm inlet turbo $100
Garrett GT35R internal 1.06 wastegate turbo (off XR6) used $1350
Titanium front pipes suit twin low mount GTR setup new, shiny, very light $850
2.5 inch wiggins clamp assemblies $250 each new in packet still have got 4 - will package deal with twin kit
Intercoolers
Spearco water/air 2-261 cooler rated 2,500hp $2000
Spearco water/air 2-281 cooler cores rated 3,500hp $2000
Trust 70mm? GTR replacement cooler used $500
Trust 70mm? twin inlet cooler new $500sold
Fuel
Tomei RB26 fuel rail new in box $300onosold
Aeromotive 1200hp fuel system, Eliminator pump, filters, regulater all new in box $1300
Waterman sprint 500 mechanical alchohol fuel pump, flows enough for 1400hp meth/3000hp gasoline not used since rebuilt from Waterman $600
NOS Nitrous kit new in box, with both single fogger and direct port for 6 cylinder $1100
NOS nitrous kit, used, still in vehicle, sngle fogger with heater and gauge $750
Engine
Cams - all for RB26 the powerhouse of all modern motors
Apexi 270 exh 11.4, 280 in + exh 11.6 new $350 each
JUN 290 11.6 new in+exh $350 each
HKS 272 10.08in 10.01ex used $600 pair
HKS air filters and pipes suit standard RB26 setup $80
Apexi twin filters and pipes suit standard RB26 $100
Oiling
Barnes 5 stage dry sump pump with -16 rail used good condition $750
Peterson dry sump tank, 3 heaters and trick baffling system used $450
OBX tank new $230
Driveline
OS pull to push conversion parts $100
AP racing flywheel and triple disc clutch, also comes with Tilton pressure plate and triple clutch to suit std input (AP) and hollinger/PPG/OS sequential(Tilton) $1300sold
R33 GTS-t half shafts/axles $50 each
Z32 LSD diff $100
R34 GTR diff $100
R32 ATS diff complete in housing $1100
Misc bits n pieces
Pulleys to suit HKS/ATI large balancer $350
Tomei R33 4 point strut brace - connects to firewall as well as strut tops - $250
R33 GTS-t radiator $80 no shroud or cap
R33 series 1 front end parts - headlights, bonnet, front bar all factory black perfect condition $800
Lenco course spline complete gear section 44% (?) no use since rebuilt $1200
JP convertor drive suit course spline lenco $1200
Ford SVO W351 intake not ported $450
Edelbrock 2991 intake ported $350
more...
RB30 block, brand new in Nissan box $600 sold
VQ35DE motor suit rebuild $1200ono
TD06-20 or 25G rear housing 10cm coated $200 or whole turbo needs rebuild $400
HKS 2835R new 1.12 rear housing $150
more...
dump pipes to suit low mount twins $150
pair of yokohama 18 inch slicks, 230/650r18 never used but stoed in garage a couple of years $300
more...
new DBA rotors suit R33 GTS-t rear $200
stock R33 GTS-t dash $150
more..
Nismo clear side winkers(indicators) suit R33 and R34 GTR 26100-rnc40 $50
Nismo diff ring gear bolts 38102-rs500 $50
Nismo long hub bolts $100gone
RB25DE complete head + block from R33 65,000k's $400
RB26 4WD sump with 4.375 gears $400
more..
Nissan CAS suit RB20/25/26 $100 each
R33 GTS-t front + rear brakes $350
R33 GTS-t rear end $350
R33 doors complete with glass and window mechanisms $200 each
R33 windows $200 each
more...
R33 RB25DET gearbox + yoke - bellhousing was damaged but have got a spare bell that goes with it $1300
RB26 700cc injectors, cleaned and flowed $500
more...
Greddy pulley kit to suit BCNR33 $220
more...
Stock RB26 afms $150
Greddy hard pipes from T88 turbo kit - from turbo to intercooler has Q45 AFM merged into pipe before cooler $200
more...
RB26 engine looms - 1xR32, 1xR33 and 1xR33 with Z32 plugs $200 each
Starter motors $75 each
Alternators $75 each
Will add more later
  • Replies 91
Rear diff, I'll pull it out and have a look. Never used or ran it, bought it for the ratios but never got too far with it.
That'd be great, thanks. Keen on a front one too if you have one laying about.
Spoke to Adam at JEM, he did the install and tune on the Haltech. He can install and tune for about $800. Although it is the old black case it has been flashed to current version of software. No difference except for the new versions are red anodized instead of black.
    • Thank you for the feedback bro. Looks like it’ll have to stay off the road till it gets an ecu
    • Only if you do not You will not be able to drive it with any serious load without risk of it pinging, which will either slowly or rapidly kill it, depending on how bad it is.
    • Hi guys, I’m new to the GTR scene. Picked up an R33 GTR earlier this year that needs a lot of love. I’ve been going through the hot side, changing all the gaskets and while it was all off I managed to score a set of -9s. It still had the stock ceramics so I was pretty happy to get the 2860s.  I live in a small country in the pacific with 0 performance car scene. No dyno’s no performance parts, let alone stock parts for a skyline. I order everything from Australia and do it myself. This means I’ll be running the stock ECU. Maybe down the track I’ll get an aftermarket set up and do a remote tune.  Will the car run -9s on stock tune safely?  I have a very heavy foot so I really hope so 😂   thanks guys
    • perfect, no rush to address the leaking bush then, it's not doing much/anything
    • I'm not sure if it will bolt up, but.... I'm reasonably sure that the ID of the runners is somewhat smaller on the NAs. So it probably wouldn't be a good match at the flange where the top and bottom meet. So that would be a reason to not do it. And the skinny runners would be the bit you're keeping, which would be a reason to no do it. You'd want the big runners if you were doing any work to swap stuff. Why not just use what you've got, like nearly everyone else who has +T'd an NA? You don't need or want the TCS throttle or other stuff that is specifically DET inlet/crossover.
