similar to tommy kaira, but not the same. Tommy Kaira is the opposite. Digital display on the left, analogue dial on the right. I did see a picture of the tommy kaira...trying to find it. Wanting to see if these are commonly available
post-1887-1195711722_thumb.jpgI believe it is a factory option - whether Nismo or otherwise, I am not sure. When I was bidding for cars through Imports 101, I put in a hopeful bid on a V Spec II Nur. We were blown out of the water on price, but Danny got some more pictures, which included the one attached.
Hope this helps.
Cheers. ;)
P.S. Not sure what the symbol is in the middle, lower half.
Edited by MLCrisis
Hope this helps.
Cheers. ;)
well yer that symbol is an R and looks like the tommy R
Yes, when I put my specs on and squeeze my eyes nearly closed, I can see it may be a Tommy K "R" symbol. If it helps, I have attached the auction sheet from that car. As far as I can tell, it is described as a V Spec II Nur. I do not know enough Japanese to know if it is referring to Tommy Kaira anywhere. Perhaps someone else does?
Cheers. :)
Cheers. :)
haha cool ta...yeah it says 'at 296km meter changed to Tommy Kaira R1'
Glad to have helped! So are you buying the car - or just intrigued?
Cheers. :(
not looking at this one...just looking at dash options for later instead of the normal nismo white dial replacement.
Cheers all :D
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
