Is it just me, or do the designers at Nissan seem to just use a basic car template and change a few little things to call it a new car?
eg, S13 and R32's have quite a similar silohuette, as do R33's and series one S14's (look at the roofline and the nose). And the more i look at the new GTR, the more i start to notice cues from the 350Z.
Edited by baron25
https://www.sau.com.au/forums/topic/194435-are-nissans-designers-a-bit-lazy/
its great for them - saves on manufacturing of parts
its great for us - makes for relatively cheap upgrades if you don't have the top of hte line model..
baron25 - you sound quite ciritcal of one of hte oldest tricks in the book..
i notice you have an R33GTS25, just remember that without the R33GTS25t and GTR there wouldn't be exhaust upgrades, brake upgrades, bumper upgrades, spoiler upgrades etc that are bolt on from the upper spec models.
personally i love that my V35 looks very similar to the Z33 350z and upcoming R35 GTR
Edited by WazR32GTSt
All car companies do this. Look at Holden for example, the VT and VX commodore are the same thing with the change of head and tail lights. People still buy the cars so they continue making little changes.
Evolutions of the same model I concede do look similar, and for reasons i assume of 'not broken don't fix it'.
But the point I was trying to make is surely it can't be that difficult to come out with a new design, auto shows are filled with new concept cars each month, some of which look quite impressive indeed. Why do these designs get shelved, and what's put out look like something that already exists. If you dislike the styling of one model, and all the others resemble it, it kinda switches you off an entire brand, regardless of what model you wanted.
It's a bit of a cop out to produce a car, then push and pull the panels a little, change the name and call it a completely different new car.
All of the car companies do it. It's called branding.
BINGO :(
All automitive manufactures have there own unique design language which consists of certain characteristics that are common accross all models in their brand. This ultimately mean most if not all models will have very similar design ques.
Just the way it is i'm afraid.
Edited by rdub_32gtst
so how did the subaru vortex fit into this "branding" :(
The odd concept with a radical design does come every so often...
The success of these designs then influence said companys design language and future models may/will draw from its design
omg, what a revelation! someone call the press!
as has been said, every manufacturer has a style that is significant, or unique to them.
styling cues that identify a subabishisan as a subabishisan tend to carry through whole model families, if not the whole show room.
and sure the concept cars look great, but they have to build something that is feasible, marketable, and recognisable as a subabishisan. if subabishsan went from being boxy and a aggressive to soft and round like their korean competitors, no ones going to buy it, the fans of the subabishisan will be put off by this sudden change, potential buyers could simply buy the korean competitor and buy their mistress a new kinky outfit, and the hardcore might even switch to another brand.
change in a brand is good, overtime you modify the design of the car, tweak this line a littler higher, make the headlights a little softer, gauge reaction and go from there, make it more appealing to the prospective customers.
blah, its 2 am, probably doesnt make much in the way of sense. meh.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
