lol. we will have to agree to disagree on this one! :( Laser machine, great for taxi-cabs, not so good for track cars. let me put it this way, look into a V8 Super car team, or an F3 team or pretty much any motorsport operation either in the pits or back at their workshop, and you will see none of them use laser alingers, and it's not down to cost.
on the topic of laser aligners, i don't rate them... i've have them done to a specified setting (they've printed out my results), come back a few minutes later unhappy with the setup and the settings that they did are different again!
beer baron recommended the kit...
it's a well made kit and very simple.
http://www.ikeya-f.co.jp/en/product_notice...a-one_gage.html
i've yet to try it, but it's really a no brainer - and i might bring it to a laser alignment joint just to see the difference.
for the price you could fabricate one yourself with some nice rulers and string, but this is a nice little package with a carry bag and not too much hassle.
only draw back is no castor, which is derived from a maths equation of camber anyway (gary any input)?
Thanks Eug,
and bb you had me laughing out loud with your post. Seems i really need to try one of these kits.
As far as castor goes, i have the whiteline bushes in mine and i would think u just set them to max and then forget about it. By max i mean to shorten the arm as much as possible, giving the most castor. Usually around 6 with these bushes.
I could be wrong though :rolleyes:
i have the whiteline bushes ready to go in as well.
however you would ideally want the same adjustment on both sides. not to mention i have had it mentioned to me previously that castor adjustments are affected by camber adjustments.
Eug,
i noticed when i was on the laser machine, working thru alignment changes progressively going from soft settings to fairly hard that if you adjusted camber it would affect the castor a little and vice versa. Im happy to be proven wrong but i think u would get the castor where u want it, and then make the camber changes.
Obviously if you are piling on heaps of camber u might need to go back and adjust the castor(if you arent already at max, assuming camber "steals" castor)
Having said all that i can notice the difference when driving that alignment changes make so maybe some trial and error is the best way to go. See what you like etc
Wheres someone smart when u need them :rolleyes:
Edited by 2630GTS
i forgot to mention in my previous post that the max settings on both sides would not necessarily mean the same settings on both sides, so there is a little flaw in that castor alignment aspect.
and yes i think we both agree that castor and camber affect one another. so which do you adjust first, and how much influence does have one setting on the other?
correct, trial and error is the go - and i'm sick of going back into the alignment shops (and spending $50-70) to get my alignment correct, and with a machine that doesn't even read accurately. once off purchase of a string-line alignment kit and i can fiddle to my heart's content.
starts with G and ends with ARY
Give a man a fish, he eats for a day; teach a man to fish, he eats for a lifetime
I am actually going to buy one of those Ikeya Formula wheel alignment kits, where do you obtain them (or should I get one in Hong Kong in January)?
good man eug, jumping in the deap end is the way to go. I have used one of the ikeya kits on a friends car in japan and it's pretty good. I've also used one we made from some flat aluminium bar, string and bulldog clips... lol.
eug and 2630GTS. yes adjusting one arm affects the other. the biggest thing to watch when adjusting camber and castor is they both can affect the toe to some degree. and toe is probably the most important of the front end alingment. there is a proper order in which to peform wheel alingment (ie, toe, camber, castor, toe) but I can't remember it off the top of my head :rolleyes: too many hits to the head I think.
rear end alingment is just as complex as you have toe, camber and what is effectively castor (rear upright angle adjusted with the traction rod).
2630gts, once you give up the laser beams you will never look back! :/ I promise.
I used to be a big fan of massive castor on the front end, and just a little camber (about 2.2degrees neg). but I've grown out of it. Things are nicer when you are getting quick with a bit less castor, and a bit more camber (more like 3 degrees neg). Toe makes a huge difference too. all this is for track obviously. the whiteline bushes will probably put your castor about right (6 degrees pos).
and just to reiterate, have a look at any top level motorsport operation. none of them have sharks with freakin lazer beams on their heads for alignment. always using set squares, dials and string lines to check and adjust wheel alignment and chassis.
PM sent Gary
you make a good point. there might be some restrictions/relationships between the settings of camber, toe and castor. a compromise between all 3 settings.
i suppose i'll try to google some methods or a procedure list as a basis. wouldn't mind to get russ/mark's input on this as well - they seem proficient in string line alignment.
p.s. - what is the traction rod, i've heard the terminology thrown around a few times. same as tension rod?
i've got the bush kits with eccentric centres sitting on my desk now. so all i'm aware of are; camber & castor
just throwing this out there, but how would you go adjusting toe with different front and rear track or with different front and rear offset wheels? The units pictured look to mount at the center of the wheel so it's a no go measuring across the car so wouldn't you have to depend on the the alignment between the front and rear wheels?
Eug,
with the whiteline bushes on max, i found the difference side to side to be so tiny that you will never notice it. Also im not convinced that there is such a thing as a traction rod i think this is more a name the japs have given it.
Consider the whiteline rear camber kit, it comes with bushes that go on one or both ends of this so called traction rod(the factory one). Adjusting this adjusts camber rather than pulling the wheel forward castor style.
Im happy to be proven wrong though
BB,
I get the laser beam treatment for free, full use of the machine so it will be hard to stay away. However it would be good to never have to go back, ill have to hit up one of these kits when i stop smokin cash on bits and pieces for teh 26/30
cheers guys
traction rod does have a small effect on camber, but it mainly adjusts the angle of the upright. it's called a traction rod as adjusting this angle effects traction. i've also called upper control arm (just like the other one), and trailing arm. but traction rod is as good a term as any. think of it kind of like a casor rod for the rear. the main way you are adjusting camber at the rear is the main upper control arm.
also, the traction rod bushes can't go at both ends as it only has a bush on one end. the other end is a fork.
Hey bb,
i was talking about the factory suspension link, u know the link that your traction rod replaces.
If you buy 2x whiteline rear camber kits then u can fit one to both ends of this link and it affects camber more than anything else. I know because i have played around massively with my rear camber on the aligning machine and thats how u adjust it, just adjusting the bush on the link that your shock goes thru wont give u much change to the neg rear camber. You need to shorten both links to get more negative camber in the rear(per side), again the whiteline kit does this by adding an adjustable bush to one or both ends of the factory "traction rod"
Also having castor in the rear sounds odd to me, i really dont think u would want to be pulling the rear wheels towards the front of the car.
I think the japs have called it a traction rod to give it some cute name, when really camber is the main thing apart from toe, that gives u traction in the rear. So really a better name would be camber rod.
Wheres the old SK when u need him :)
Edited by 2630GTS
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
