Ok looks like we have a fair bit of interest in this i will run past 2 tint fitters on friday and see what they can offer for 10 cars
but people if you want a group buy price i hope you realise it's money down up front, that being said ill be hunting for a price to make you say dang i wish i had of waited
  • Replies 41
I'll check out a couple of places to for prices, what suburbs you looking into
Edited by WLD MAN
main north road and regency road so not sure of the suburb name 100 meters down from that intersection
i think there called auto perfection and i will be looking into scorpian tint
i know both places do top notch tint so really not sure how cheap i will be able to get it but we dont know until we ask
Hillzy when you ask you dads mate tell him we want like wholesale prices
i havnt counted everyone in this thread but im guessing there is 10 maybes and we have R31skylineclub to ask and NS.com can jump in on the group buy remember the more people we can get to put there money in the cheaper is should cost to a certain extent
for a business i did the math on 20 people paying $200 and that would be a whopping $4,000 in there bank in one hit and we all get booked in over the 1 month period. now im not sure if we would even reach 20 people but then i remembered the other 2 clubs and thought it may very well be feasible
OH btw im looking in the Enfield area i think its not toooo far for down south and if your saving a packet then does it really matter if you have to drive 20 mins to get you car tinted
i got my car done at Tint-A-Car Murray Bridge, the guys were awesome down there and did an A one job, it cost $375 for Midnight Express, the darkest legal tint available,
certaintly worth the drive lol :D , but at the time i was working at tailem bend.
I've called around... and heres the prices I got:
Tint a car - Port Rd: 84478097 - $220+tax for 35%, 20% cash job only
- Holden Hill: 82666402 - $250
Scorpion Window Tinting - Enfield: 83590554 - $320 each - top of range slight metallic in it, $250 each flat black mid range, $220 35% standard stuff - all with warranty both 35% and 20%
United Windscreen: 82694444 - $170 - 35% - lifetime warranty
for 20 cars variations of Skylines and Silvias......
Edited by vietorious
if its cheap ill be in
make sure steve that you gat prices for 4 door skylines as well as 2 door as im guessing theyll be different as well and stageas haha
Stageas have black glass on the rear windows, its only the driver and passenger window that needs to be done, so id hope they would be even cheaper...lol
what kind of tint are you guys inquiring about.... will microwave sensors work through it? cos apparently if the tint is metal based you might as well throw out ur microwave sensor, it blocks the signal from getting out of the car
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
