Hey guys
Not sure if this is the right section or not but anyway.
I done a bit of a braking test yesterday to see how well the abs worked (stupid i know, but i was curious to see how well it worked :P) so i was doing about 100kph then put the brakes on as hard as i could, while coming to a complete stop the oil light came on ( the little oil can symbol that lights up red on the top right hand side of the cluster) i didnt keep my eye on the oil pressure gauge so i dont know what it was reading.
Is this something i should be concerned about ,the oil level is just above the full line, my old r32 gtst actually done the exact same thing. I am using the stock brake setup with 235 front tyres, so somehow i dont think this would be enough to cause oil starvation while under hard braking but please correct me if im wrong.
Any comments would be great :(
Cheers
https://www.sau.com.au/forums/topic/194663-low-oil-pressure-while-braking/
Depends, If you were pushing it real hard before you started braking, then you've probably got a lot of oil in the top half of your engine, then the braking might be enough to make it appear as though the level is low?
Although I'd imagine that the GTS-T sump is fairly well baffled?
Nope i wasnt pushing it, was just cruising at 100kph then put the brakes on.
it doesnt hurt to run it over the full line to keep it safe. there may be other issues with your oil control system to cause it to surge under breaks..
Yea i always run the oil level a bit above the full mark in all the skylines ive had, any ideas on what other issues there might be? The sump is in perfect condition (no dents etc) and i change the oil and filter every 4xxxkms ,i use castrol magnatec 10w40, the car has only done 86xxxmks.
As i said above my o0ld r32 used to do the exact same thing, is there anyone willing to go and test it on there own car to see if the same thing happens?
Cheers
the common oil pressure sender fault usually manifests as a problem with the pressure reading, but i have never heard of the oil light coming on with an oil pressure sender issue...
i would be keeping a real close eye on it
if you ever see the light again, shut the engine off immediately
but if it were me i would be considering getting an expert opinion, because if its the oil pump that is dying and you don't fix it, you could be up for a new engine..
the oil press light is driven by the sender also... so if thats faulty then its going to makle the light and guage read wacko
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
