  • Replies 116
bump, more parts added/updated, split things into groups to make it easier to read
Chassis has subframe, rear window, rear quarter windows, would be good for a rear cut or something
Also has engine plate/compliance plate, car not listed as a writeoff or anything
$500
or $680 delivered via tow truck to your door SA metro only
if not off to SIMS metal or similar
Hi I am chasing a drivers side rear QTR window and shipping to Darwin.
If you can cut it out let me know a price with shipping
Regards Devo
$500
If I have to cut it out myself I'd want $90 for the driver rear quarter window this is including delivery to you in Darwin
need to act soon may be going to wreckers this Wed
hi im interested in cluster surround wot does it include pic preferably i will forward 20 bucks ur way is it a series 2 cluster
bank details
Hey man just wondering if you had this clip?
sorry sold rear wiper and motor today, brakes are not for sale
shell looks like it's been sold now as is
cluster surround is just the plastic piece that sits in the dashboard in front of the cluster (ie surrounds the front of it if you get what I mean), comes with screws, all parts from a Series II (the actual cluster/odometer has been already sold)
Hey, was wondering if you'd split the interior trim so I could get just the driver's side A-pillar trim? Mine's got some rather horrible holes in it from the previous owner installing a boost/AFR gauge.
the A-pillar I have also has 2 or 3 screw holes in it, make an offer
seriously if you want me to split gear up make on offer, my prices are up there as is and some bundles are fair cheap already, if you need things broken up then make an offer at the same time
sorry front windscreen smashed
ok would u be able to send it to melbourne give me bank details and tell me wot i should put on the remitter and i will pay
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
