  • Replies 72
  • 1 year later...
1/2 Maltese x 1/4 Bichon Frise x 1/4 Poodle
his name is Oishii, which means 'Yummy' in Japanese... we didn't want to eat him, he was just brought home in a Yum Yum Noodle Box lol tiny bugger
he's a bit bigger and way crazy now though haha 3 years old now i think, now lives with my sister as she's moved out
5 cats in order from eldest to youngest - Charlie, Merlin, Spike, Zeus, Hades.
5 Cats?????
I have one named Gabriel Ninjacat. Yes, that's his pedigree name!
Edited by fire_angel
my brother once had a jack russell cross with a cool name
Sinsemella Buddlington Wadshot
We have a rottie named Lilly (real name is Glencoe Makea Move)
and a beagle named Sophie, aka Jihad Jackie The Tap Dancing Terrorist
5 Cats?????
Yup, 5 cats :(
When we get a bigger house (or I build a bigass cat run out the back), we'd like to get a Maine Coon - the biggest domestic cat breed you can get (not one of those wildcat cross jobs).
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
