  • Replies 72
  • 1 year later...
1/2 Maltese x 1/4 Bichon Frise x 1/4 Poodle
his name is Oishii, which means 'Yummy' in Japanese... we didn't want to eat him, he was just brought home in a Yum Yum Noodle Box lol tiny bugger
he's a bit bigger and way crazy now though haha 3 years old now i think, now lives with my sister as she's moved out
5 cats in order from eldest to youngest - Charlie, Merlin, Spike, Zeus, Hades.
5 Cats?????
I have one named Gabriel Ninjacat. Yes, that's his pedigree name!
Edited by fire_angel
my brother once had a jack russell cross with a cool name
Sinsemella Buddlington Wadshot
We have a rottie named Lilly (real name is Glencoe Makea Move)
and a beagle named Sophie, aka Jihad Jackie The Tap Dancing Terrorist
5 Cats?????
Yup, 5 cats :(
When we get a bigger house (or I build a bigass cat run out the back), we'd like to get a Maine Coon - the biggest domestic cat breed you can get (not one of those wildcat cross jobs).
