  • Replies 44
I would assume it would be slightly me responsive being ball bearing as opposed to journal (kkr items are journal bearing type are they not?) ...
also aren't the kkr series only oil cooled whereas the HKS item is water and oil cooled??
if I could have my pick I would have anything HKS put on my car over anything else on the market :D
Don't get me wrong, I love the japan stuff, but he already has the bigger KKR. A 2530 won't make the same power. It's considerably smaller. If we're talking a comparable Jap turbo you'd be looking at something the size of a 2840 or a GT30 I would think?
only making around 295rwhp
yes its laggy bout 4500rpm full boost
the car with 2530 on it i took it for a drive last nite, very good low down torque and mid range wheel spins coming on in 2nd but yeah
i dunno wot to do lol
help me!!! some ppl say 2530 2 small for rb25? im only really after 300rwhp would 2530 get me there easy enough?
well the motor has 250,000kms on it and ive been running 19psi thru it for last 6 months
so 300rwhp is pretty much the limits i think and response would be nice my thing is laggy as hell haha its a joke!
obviously you're unhappy with your current lag and you've seen the down low response of the 2530. whats holding you back?
250000kms? wtf juz?
295RWHP@19psi, with fully boost at 4500rpm = VERY SHIT TURBO!!
For a turbo to make full boost at 4500rpm i would expect it to be pretty damn big and make at least 330rwkw (450rwhp)
Kkr's aren't shit ..
however the kkr430 would have been the better option... unless you want to use it for just drags etc. it's not going to get great response with a stock engine,
John Cane runs (drifter) runs a kkr430 on his Rb25det in his laurel and it goes awesome!
Read specs here > otomoto
Edited by RB_turbo_bitch
I had a HKS 2535 which is a little better but I have been in an RB25 with a 2530 on it and there is almost no lag! It was an awsome street car the only downfall it had was that you couldnt push it to redline you were better of shifting at 6 - 6,500 rpm...
I would do it.. it will make about 220 - 230 max but i have seen them run mid 12's in an R33.. PM Robo's on the forum, he had one.
Its not all about rwkw.... from how laggy you have said your turbo is, the 2530 would destroy the kkr setup on the street even if it was making a bit more power.
    • Today, I'm a Breville BES920 tech, new triac board and new 3x way solenoid. Had overheating issues, home RCD tripping when it got warm, and the boiler stayed on when the machine was shut off. Also, usually 3x way solenoid chatter, this is the 3rd time I'm replacing it. Mind you, this machine is 9 year old and send it every day doing at minimum 3x double shots. When the in laws come over to took after my daughter, it will easily see 6x double shots in a single day. Tried to be somewhat compliant, crimped and then used a screw connector over the top. Would have preferred to use heat shrinks.   After all that, turns out all the overheating has damaged the o-rings to the steam tap as well. Ordered new ones, coming soon.
    • Still got it- First time checking sau in a while ahhaha
    • I don't know about that. I can hoon my R32 around - hard launches, high lateral Gs - with <<1/4 tank without any such shenanigans. This with the previous 040 and the current GSS342. I would suspect a fuel line problem. One of the hoses associated with the top of the tank perhaps.
    • This is amazing. Love that you’re giving the boys an intro to cars and off the screens. They probably have an insta for the car and build posts on TikTok for their mates.
    • It is.  Your car works fine with the tank full. If you drive like a Nana it works fine.  You give it a boot full with half a fuel tank, you get surge.  It 100% is a fuel surge issue. Maybe have a look at installing a Hydramat if you don't want to install a surge tank.  https://www.holley.com/products/fuel_systems/hydramat/
