Hi guys I'm pretty sure this plug is for the factory mobile setup, but does anyone recognise what phone it would plug into? would it be worth changing the plug to match my Nokia phone plug? How easy would it be to change it?
cheers
Edited by vspec2
https://www.sau.com.au/forums/topic/195049-v35-factory-mobile-phone-setup/
that said if its like every other dealer fit option I've seen onthese It can be modded to take another nokia - benz did a similar thing.
Chris
You're like an encyclopedia, thanks mate!!!
I'll give you call about the DVD headunit sometime this week.
cheers
Alain
That's cool! I've read about it, but haven't seen that before. Does the other side of the steering wheel have controls for the stereo?
What model is your car?
Might want to check to see if it can connect by bluetooth because I have read that it was an option.
Hi no controls on the other side. the top and bottom buttons control the stereo volume and change tracks and radio stations.
2005 6MT
No Bluetooth I'm afraid tested that a while back.
cheers
would LOVE to play with this. (especially since it was a dealer fitted option..) anyone in brissy got this?
Hi Chris , got 1 off the wharf today 05 6sp , ready to comply , will have to ring you and talk . on the southside of brissy as well .
Regards Brad
brad,
thanks for today.
for the record that unit is BUILT INTO the car similar to what lexus did in the 90s with motorola. my thoughts would be to find the phone that runs it and use that. nothing else can be used. this info is based on the above car.
cheers
Hi, I just picked up my 6mt 06 last week after a lot of red tape, it too has the same phone connection.
Is there a way to get the bluetooth to work?
Hi
The buttons are for the phone only so they dont control any audio controls. When you press the phone button it displays the phone menu on the sat/nav screen prob shows phone info etc.. If I can find a phone that actual works with it I will give an update.
cheers
hey guys,
i have the same phone connector in my car.. I went through the manual and it says that it is only compatible with au phones. For those who don't know au is a CMDA-1 phone network run by KDDI in Japan. There are quite a few phones designed for au by different manufacturers so I am assuming that all of these phones must have the same connector? Check the lineup here.
There's a Sanyo phone there under global passport which is gsm and cdma so that should work.. But I really would prefer a phone adapter :)
Just did a bit more digging... you basically need the reverse of this cable.. I actually have an adapter that does the same thing.. just need to reverse the flat connector
Edited by karim
  • 4 weeks later...
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
