Hey all,
Im looking at buying some front vented gaurds that are 30mm wider than the standered ones. So im guessing my wheels now wont fill out the gaurds...
So i may look at some new wheels. What offsets and width should i be looking for?
What sort should i be looking at to fill out the gaurds more now... Want some dish... and under or around $2000...
Any help would be great..
Also looking at some rear over fenders... but how are these held on?? am looking to try and do it myself... ideas?
Edited by Adz2332
https://www.sau.com.au/forums/topic/195544-filling-out-the-gaurds/
we usually grind the rear quarter back to metal, then use 3M Automix to adhere the fibreglass directly with the exposed metal... reinforce by drilling and resining through so that the overfender doesn't move around and cause hairline cracks in the paint a couple of years down the track. If the fender allows for it we may pop rivet as well for additional reinforcement, but not where the rivet has to be covered by filler to hide it, as a couple of years down the track the filler tends to shrink around the rivets and show dimples.
3M Website for Automix
He's reffering to Front vented guards (replacement) not rear guards.
As for the front guards, it says 30mm wider, but they actually taper back into the door and the front bumper, so they are only 30mm wider at the middle of the guard then meet back to the factory bumper mounting points, its abit hard to explain, but when i had these guards on my r33, i could only space them out a extra 20mm or so, before rubbing. As for offset around +20 should do.. If using a bolt on spacer, go for the minimum size of 25mm, you should be fine, aslong as the car isn't overly low.
ahhhh pop riviting to the car.. hmmm no way you can do it without damaging panels??
Most people use this technique because it's cheap and it gives that 'tough' look to the car, but I don't think it's the look you're after.
+20? i reckon you could get away with lower than that
i had 17x8" +32 on the front of my r33, and it wasnt flush with the guards, so if you are putting on another 20-30 mm, you should be able to sneak in a gtr-ish offset rim, like +12, even if you have to add a degree of camber :)
that said, it depends on what widths you want as well..
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
