Just some pics ive taken recently at our last 2 meets
who has the sexiest pair of legs?
1 fine looking bachelor
Matty31's ute? and Bunny's hand?
"I swear i stashed the cash in here somewhere"
mmm, EVO VII
..and at Semaphore
Edited by andz
https://www.sau.com.au/forums/topic/196093-sau-pics/
Hey Steve, have you thought about getting spacers for your wheels?
The look is good becauase its different to most other 33's, but they do sit quite a long way in :(
https://www.sau.com.au/forums/topic/196093-sau-pics/#findComment-3510186
Yeh true that, never noticed it before!! You'll be surprised that just adding spacers can make your car handle better, by making the track width wider, can settle a car down a bit!
https://www.sau.com.au/forums/topic/196093-sau-pics/#findComment-3510219
I got told NOT to cover my tat with Glad Wrap, but to still put bepanthem cream on it and let the fresh air do its thing!!
Where'd ya get it done??
got it done at ink wizard by my mate your ment to leave the glad wrap on for a coulpe of days i was told by my mate and hes covered in tat's
https://www.sau.com.au/forums/topic/196093-sau-pics/#findComment-3510552
The look is good becauase its different to most other 33's, but they do sit quite a long way in ;)
yeah i had but insurance companies like that mod the least
I'm getting Dans drift teks so that should make it sit better, while i didn't mind the rims in the beginning I'm well over them and the front bar,
i also think those rims never got made in a offset to suit skylines there more a 180, Silvia rim
https://www.sau.com.au/forums/topic/196093-sau-pics/#findComment-3520448
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
