  • Replies 318
Whats my sau member number Duncan? I am going to be buying a helmet too.
Hey Albert when are you going to buy your helmet. I'll come with you perhaps they'll give us a better price if we buy 2 at once?
sending you pm
you have msg mate :blink:
My god I'm excited.......finally I get to do a Oran Park GP track
anyone got a few stop watches handy?
Hey james which day are you going in?
scoobs, can't wait to see your toy, its great to see another race car in the club
sheng and any others, I can provide a license for club members on Sunday. And I can organise membership for anyone new.
We got helmets today :)
also the CAMS approved fire extinguisher was $32.99 at Repco
Are black leather shoes suitable, or do the shoes have to be covering over the ankle?
got my for 29.95 from supercheap :P
got mine for 27 from auto1!!! :P
Edge - it will certainly make a difference if you bleed the whole system and fill it with dot5 etc
even without that, you sould feel a difference im sure.
scoobs, weather depending!! :)
Don't worry too much either way about the discs unless your old ones are rooted. - but it is a very good idea to bleed the brakes with a good fluid like motul rbf600. Average brake fluid will probably boil up, and good quality fluid needs to be replaced every 12 months anyway.
Daniel I've never been questioned about shoes, although I guess thongs are probably out of the question. You will need long shirt and pants I normally wear jeans and long sleeve cotton tshirt (cooler for this time of year)
BTW has someone double checked that these days are still on?
I rang them a few days ago and it was still on.
I just noticed my right side front sway bar bracket has snapped! :P not sure if I can get a replacement - I'll try to visit Justjap and get a replacement tomorrow morning. Rang them, got the cleaner there who said they havn't closed for Christmas yet
Do you think the rain in the morning will make it so there is more track time to the people who turn up on tomorrow on Saturday?
Since I'll probably be fixing the link on my car in the morning this might work out well.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
