  • Replies 318
nah i'll be in queensland.. i wanted to come though....
no idea on times...need a lap timer thingy...
i still have a missfire issue to deal with too...
keeeep trackennn it!!!
it will go away..
oh I see!
well, as Albert would say - just keep trackin it :) haha
good to hear you've been enjoying it out there man :)
oh you beat me to it ;)
yeah good to see you had a good time out there mate!
More dates guys :)
Hi,
We still have the following days available for Private Practice
January 16th GP Circuit
17th South Circuit
19th & 20th South Circuit
21st GP Circuit
23rd GP Circuit
25th South Circuit
27th & 28th South Circuit
There are some possible February dates yet to be confirmed
Regards
Hi,
We have the following days available for Practice
January
23rd GP Circuit
25th South Circuit
27 & 28th South Circuit
February
3rd South Circuit
4th GP Circuit
There will be other days available in February contact us early Feb for dates.
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
