Hey,
I need bigger injectors bad as under full load i'm hitting 97% on my injector duty. I don't really want to go to the trouble of putting on a fuel rail. I kow you can still get big injectors that screw in and I guess my question is what is the biggest size CC injectors I can fit into the RB25DET.
Cheers. She needs juice. lol
https://www.sau.com.au/forums/topic/196636-bigger-injectors/
Nismo 550's will be more than enough for your turbo (they support 300rwkw no problem).
Largest - I used Nismo 740's for mine 369rwkw.
Stock Rail, Stock Reg etc etc.
I think Sard's in the 800 are also direct-ish fit
396RWKW!!! Thats massive man! What are you running?
Cheers for the advice. I cannot wait to get all the kit on. Iv'e gone a bit silly but whatever yeah! Not long till all the parts come in and i'll be aiming for around the 290 RWKW mark. To tell you the truth i don't really want more than that. I still want to be able to drive her on the road.
Cheers
Kane
Why do tuners tell me to get bigger then 550cc if they can handle 300rwkw
im looking at between 240 - 260 rwkw
Highflowing injectors are abit cheaper then getting aftermarket injectors but i hear they arnt as good, can anyone confirm this?
Edited by SLYNE
Because they are full of shit :D
No other reason, or they are trying to sell you something that you simply do not need.
Because they are full of shit :P
Nismoid,
As I am at the stage of installing a whole heap of gear I need to make sure I make the right decision when it comes to Injectors. Can you point me in the right direction as to where would be a good place to get the standards flowed. Or even someone to talk to about this.
Thanks Mate!!
A good option for cheap injectors is 480cc ones out of manual S15's, they are a direct drop in for R33 RB25DET's.
I'm aiming for approx 260rwkw and 6 of these will easily suffice, and only costing me $280 delivered for all six.
Edited by stolen_s15
Nismoid,
Thanks Mate!!
There have been a number of threads with suppliers/prices and so on.
Just search with "hi-flow" "injectors" and you'll be right
Personally i wouldn't use hi-flowed injectors.
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
