  • 6 months later...
Paul! Do you still have tha Apexi led flashing gizzmo that I won ages ago?? lol
Yes I do, I can drop it round after the long weekend, PM me your address again.
Sorry about that Charlie.
  • 1 month later...
Im unable to edit the original post to say the inj are sold, so except the INJ if there is no line though it I have it.
Thanks
This is whats left. with a price drop
Apexi PFC Boost controller (as per pic) $100
Turbo’s STD Balled R34 GTR VspecII 20,000km old, pair $650
CAM’s STD R34 GTR VspecII 20,000km old, pair $300
(Great upgrade for non vspec apparently 255 deg instead of normal 250 and GTT')
ECU STDR34 GTR VspecII 20,000km old $100
AFM STD R34 GTR VspecII 20,000km old, pair $75 1 is slightly damaged with a cracked and repaired hole, but working fine
HKS Metal air pods from R34 GTR pair $100
Boost Solenoid STD R34 GTR VspecII 20,000km old $20
AFM STD R33 single, please try before you buy $35
Fuel pump R32 GTR $140
Aircon/climate control Module R32 GTR $100
Variable cam sprockets R32 GTR pair $80
HKS air pods (Plastic from R32 GTR pair $60
AFM STD R32 GTR pair 80,000km $60
Front strut brace R32 GTR $50
Variable cam sprockets R32 GTR single exhaust $50
Turbo R32 GTS working $100
Turbo R32 GTR BLOWN, needs rebuild single only $50
Turbo SR20 NEW and not used $400
Fatz bargain basement!
I know you want them Fatz, just because they are cheap!
Sump baffle/de-fuser STD R34 and R32 GTR each $40
Spark plugs iridium heat range 6, 5,000km old 6 units $30
Horn R32 GTR $20
Thermostat 76Deg R32 GTR $20
  • 1 month later...
OK,
R34 Turbo's, AFM and ECU sold. Also R32 Cam sprockets
CAM’s STD R34 GTR VspecII 20,000km old, pair $250
(Great upgrade for non vspec apparently 255 deg instead of normal 250 and good for the GTT)
Fuel pump R32 GTR $100
Horn R32 GTR $20
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
