Hey Guys
I have just purchased and installed the famed GTRS and it has this loud whistling noise, when at idle and then reving the engine it will whistle through the air filter around 3000rpm onwards, but when you drive the car as you are accelerating it will produce the more whizzing sound (best described as similar to the engine noise sound you get through your speakers) does anyone else have the GTRS with a pod filter fitted that can tell me if theirs makes or doesn't make this noise or if it is normal.
i have tripple checked for air leaks, gasket leaks - and can gurantee it is not the fuel pump.
any help would be much appreciated
Cheers
https://www.sau.com.au/forums/topic/197148-hks-gtrs-whistle/
Guest R34GTRGODZILLA
Yes i have a GTRS on my S2 Stagea auto, and when under way when i back off in say 2nd around town, (backing off only a little) and then holding the revs i find i can hold the whistle noise and can produce a rather loud whistle. But under full load it seems to be like any other turbo noise. Infact i reckon it is slightly quieter under load than the last turbo gcg that was on the car.
My HKS GT3037 makes a sweet high pitch whistle just like a jet engine starting up.
The old hybrid was more of a lower whoosh noise.
I will try and video it next time its on the RR from the front to see if I can catch the noise.
Yeah i might try to see if i can get the sound on camera as well,
I get the noise as soon i start accelerating.
Its the anti-surge housing. My GT30R does it too:
http://www.youtube.com/watch?v=ClXcNtAMJjg
Sounds just like mine mate. What was your boost and power?
Done 280rwkw on its last run on a hub dyno at 1bar of boost. Not too surprising it sounds just the same, its basically the same as an HKS GT3037 Pro S ;)
Edited by Lithium
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
