OK so I ran a search and looked here and there, many running a few piston types and brands. Looked through the thread in the quick ref as well. Something that seemed to be missing from many of the threads were a few possible choices and perhaps some info. I am wondering why I don't see many if any Jap brand names being thrown around, is it purely price? So far I have learned Venolia are at least 'buyer beware' and most others are quite good as long as the clearances and ring choice are right. That and the engine builder doesn't do something dumb :D
So how do the Jap brands stack against the more common ones I see here? Is it purely jap brands are too expensive or are there other issues? How many actually manufacture their own or are just reboxed?
JUN
Tomei
HKS
Wiesco
CP
JE
Arias
ACL
https://www.sau.com.au/forums/topic/197191-piston-choice/
jap brands tend to use the best pick of piston manufacturers and use specific models, ie the trust pistons i use in the top SR's i build use a crown design and special ceramic coated rings only available under license through trust even though the manufacturer makes "other" SR20 pistons.
Arias are a good budget brand and i use them mostly on budget builds but i am not a fan of dished crown in any HOT SR20 i prefer the flater notched crowns, i am currentley building a test engine with SRP (JE). so i will soon know what they are like.
i dont know of any jap manufacturer that manufactures their own pistons but most are made to spec and are not available in another brand or boxes, they are made under license.
https://www.sau.com.au/forums/topic/197191-piston-choice/#findComment-3526353
Interesting. Personally I am looking at a Tomei forged piston kit for my RB25DET however I'd have other things to sort (like being able to drive while R33 is off the road) before embarking on a full rebuild.
https://www.sau.com.au/forums/topic/197191-piston-choice/#findComment-3526368
you need to look a a few things to determine whether or not you 'need' the extra benefits offerred by these dearer pistons, on many builds i will talk a customer down and prefer they spen money elsewhere for their application but for extreme and high hp and high rpm i prefer the jap brands as they tend to offer a better life cycle and in SR's they offer a unique crow design and ring combo..... oh and zero noise.
https://www.sau.com.au/forums/topic/197191-piston-choice/#findComment-3526392
Mostly what people think are a good piston rather than actualy using them but still a bit of info there.
So JUN/Cosworth, HKS, Tomei if you're 'loaded' or chasing big power figures otherswise CP, Arias, Wiseco etc will do the job cheaper. Venolia if you want to brake something.
https://www.sau.com.au/forums/topic/197191-piston-choice/#findComment-3527462
ACL and CP pistons are both very good pistons for the pricing... I personally prefer ACL as they have a better ring kit... Piston wise they are both very comparable quality....
I'm personally running ACL pistons and have had no problems
https://www.sau.com.au/forums/topic/197191-piston-choice/#findComment-3527639
you say hks and jun pistons if u chase big "power figures" who said u cant make 1000hp with a set of CP's? a set of well made forgies is what you will need. You can get a rebuild kit from racespec for a couple grand..
Edited by LTHLRB
https://www.sau.com.au/forums/topic/197191-piston-choice/#findComment-3528520
i can see where he is comming from though. he said some manufacturers have certain technologys which is only available by licence so you will need to go with the jap brands that have this available to get it.
https://www.sau.com.au/forums/topic/197191-piston-choice/#findComment-3528527
what has stopped the old boys from making 800hp in a big block v8 n/a?
if you want to have that backing then yeah use jap brands.. but i would only use jap brands if im using a full kit (stroked engine) like full hks, tomeii or nismo.
just talking like this because iv seen ALOT of engines built with arias, acl, cp and wiseco
https://www.sau.com.au/forums/topic/197191-piston-choice/#findComment-3528557
nothing is stopping anything. i have ACL pistons in my engine as im not made of money.
I would like to have the jap stuff in my car though.. they build more RB engines then us... well that might change soon though lol
https://www.sau.com.au/forums/topic/197191-piston-choice/#findComment-3528858
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
