Basically I am about to take my R33 form 231rwkw to around 300rwkw. My question is how much power can the stock box and drivetrain take before things go bump in the night. I already have a heavy duty clutch that apparently will take 300. Any input would be much appreciated.
There is no solid answer.
It will depend mostly on the current health of your box, and what you use the car for.
But 300rwkw for street duties if your box is in ok condition should not be a problem.
think of it this way. JET200 uses a rb25 box and pushes about 315kw.
and has a r33 diff. it worked well man. but why not just plop in a 1.5 or 2 way for insurance.
Thanks for the advice. I figured as much but thought i'd be sure. The car is only 89000 on the clock & the box still feels strong. I do need to get a service on it as i can feel the syncro's when i shift into second. I think i might see how much it would be to get it strengthened while it's out of the car.
Man I'm shitting myself with the amount of $$ i'm starting to clock up on this puppy. Oh well you only live once right. At least she will be a mad setup when its completed!
Cheers
369rwkw i ran @ the drags through my 33 box. no problems... but then i didn't have much traction which is also a factor
Wholy shit! what does she run? have to be 10's yeah. Awesome Nismoid. You freak. lol.
I am not looking to push the envolope that far. Be happy with 300rwkw on streets! I'm just in the process of talking to a mob called Custom cars to finish off all the work.
I'm getting
Tein Coil over
Slotted rotors
Oil cooler
Oil filter relocation
Apexi Power FC boost controler
HKS 740 injectors
Plenum
Exaust manifold
Throttle body
Alloy radiator
Bigger cooler with custom pipeing
Not to mention the container of Carbon we have coming from China. Sweeeeet.
You know of any good shops in S.E Melbourne who are reasonably priced????
Thanks for the advice anyway Nismoid. You obviosly know your shit.
Driveshafts will break long before the diff centre. The VL boys are running 9.50's with a stock R33 5-speed and single plate Jim Berry clutch now so your power expectations should be nothing to be concerned about.
They are smashing third gear eventually though, it all depends how hard you thrash it. 300rwKw will not be an issue and if you want a cheap way out with the rear end throw in a GT-R diff + larger shafts.
Edited by PJ.
  • 5 weeks later...
Cheers mate.
I thought i'd have a look at the oil in the box anyhow and f*ck me. I'm going to have to strat looking for a new box soon. Heaps of metal fileings and even a couple of little like clips. 4 of them. That would explain the crunch i get into 3rd & 4th on full boost. Man I hate this crap that comes and bites you in the ass.
Considering your Melb... some of your mods will get pretty nasty if you get EPA'd... going to cost you a LOT of money (many thousands) to get it passed.
There might be a smarter approach (tha potentially will save money/hassle) :blink:
That said, go visit RE Customs (Springvale), they have been doing great work and are probably the closest off the top of my head.
Here's a tip...... they're never complete!!!!!!!!!!!!!!!!!!!!!!!!
There might be a smarter approach (tha potentially will save money/hassle) :)
Cheers Nismoid.
I am doing my best to keep it all looking stock as possible. Well excluding the carbon mods. It is a bitch of a thing. The good thing is I'm in the Army reserves and My ID normaly gets me out of those sticky situations. lol. Another good thing is I do know of a dodgy russian workshop that'll pass anything within reason of course for $150. lol. Sh!t how do you think I got her on the road in the first place. lol.
Cheers heaps for your advice.
Currently I am having an absolute nightmare with my sound install. It's 5 days since the guy said it would be done. I went in last night and lost the plot. He was like what do you think of the boot. I said SHIT how the F*ck am I supposed to show this. Ahhhhhhhhhh. I wish I just paid the full amount and got a well known mob to do it.
Lesson learned there.
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
