would have come man - cos usually on fridays i have nothing on...but this friday i have a friends wedding - even had to miss the ANZ xmas party - a party that usually filled with a lot of hot women :domokun: *sigh*
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
