Dudes,
Basically here is my setup:
RB25det series one motor
PFC
Full 3" zorst
Z32 fuel pump
Z32 Afm
Apexi Pod filter
Adj fuel regulator
I recently swapped out my stock series 1 RB25det injectors with S15 480cc ones.
I followed exactly what was listed in the forum write ups on how to do the swap which was pretty straight forward.
....but now...she doesn't fire up! :(
Somehow whenever I turn the key the fuel pump will go for abt 5 seconds but the fuel press does not rise, even if i turn the key off and on a few times to get the press going. When I turn the key 2start she sort of cranks just once then the panel lights dim as if the starter is jammed! Battery voltage is 12v, the new inj settings and latency has been corrected and there is fuel heading towards the rail....
anyone experience this before? what gives?
your help is greatly appreciated!
Cheers :(
Edited by a31gtst
https://www.sau.com.au/forums/topic/197406-help-s15-injector-swap-to-rb25det/
Mafia: the FPR was working fine before the swap
URAS: have you experienced this before? I carefully lubed the orings wth rubber lube and inserted the injectors into the rail slowly and screwed the injector caps very even and consistently. I also turn the injectors around in the rail a few times to ensure that if the oring was pinched i'd feel it. for hydraulic lock happen i'm guessing the cylinders have gotta be really filled with fuel, but in this case the only amt of fuel that has gone in is when i turn the key to ign and the pump turns for abt 5seconds... still i'll check out the cylinders from the plug holes to see if their filled.
anyone else have any ideas? god i hope the damn motor's not jammed!
Cheers
What is the battery voltage while you are trying to crank the engine? Have you tried boosting the battery with a jump-start?
What happens if you remove all the spark plugs and crank?
Batt voltage is a good 12v, lights, fuel pump and starter are nice and juicy.
haven't tried with a booster battery...am afraid i might fry the PFC...
check your o-rings on the injectors... i see this like 3 to 5 times a week... customer installs injectors and the rail wont pressurise because the pump is pumping fuel str8 past the damaged o-rings into the cylinder and the car hydraulics and wont crank. remmeber the injectors have TWO orings one large one at the top and a small one at the base... many forget the small ones at the base.
Thanks URAS,
I believe you hit the nail right on the head! I recall very clearly replacing the big o-rings but not the small ones.
holy christ! now i've gotta remove everything all over again..haha.
once this is done and i have cranked it without the plugs in, is it safe to put plugs back in and start?...i wont risk blowing anything right...with all that fuel sitting somewhere...
drain oil and change oil filter, with that much fuel in the cylinders you will find that alot of it has drained into the sump and diluted the oil... if you dont change it worst case scenario is a sump explosion if there is a LOT of fuel in the sump.
drain oil, change oil and filter and you should be laughing.
Yeah mate did a similar thing to this, bought some injectors off me, put the top/bottom o-rings in correctly but accidently split the bottom o-ring on number 6 injector and didn't notice. Had no exh manifold at the time. Remember standing back as oldmate cranked it and another dude was infront of me looking at the motor then hellloooooo flame ball to the face lol.
But yeah back on topic agree totally with uras.
Edited by James_03
Opened the plugs up to check... Cylinders 1 thru 6 were filled with petrol!
Drained everything out, put the o-rings in, added some oil in each cylinder b4 putting plugs back in...voila...it started!
ran like a bitch tho...prolly fouled up by the oil...
drained all the oil from the sump...man, it was more like black petrol! approx 7 liters of fluid came out..i'm assuming i must have had 2.5 to 3 liters of petrol mixed in the sump!
Filled in new oil and replaced the oil filter...started up rough but after 10mins idling she's back up to mark.
Thanks URAS....
Btw, to those of you swapping injectors... make sure you check ALL o-rings are in and are not damaged.
you can use rubber grease on the o-rings to lube them, the injectors should pop straight in with ease...
Cheers!
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
