  • Replies 78
On a positive note, it shows that many of us are very passionate about our car, and our skyline model of choice.
Most of us had reasons for choosing the specific car/model we did, over all the other skyline etc. models available.
However I agree its unfortunate that people feel the need to take it further than necessary when debating the pros and cons of each model on here...
Look at it this way, if there weren't so many different models of skyline, half of us probably wouldn't be driving one...
There's a saying "a war to end all wars..." I think all Skylines are nice in their own way and subtle features!!! From the R31 to the R35 - all Skylines are nice and unique. Its just people have personal taste - the same goes for foods, clothing, music and whatever else.
those R33/4; looks fkn shit house imo.
looks like some imbred cheap conversion that the japanese equivalent of Aus bush mechanics have put together.
the face just dont match the arse! a nice curvy rear with a boxy edged front
:vomit:
Edited by MSPEC33
Was never a fan of the D-wing on a R33... but the front conversion look hot as...
How has this thread gone 4 pages without anyone posting pictures of this car?
http://www.skylinesaustralia.com/forums/in...t&p=3106723
There was a link to that car posted by nice 28. Good enough.
ive been looking at these over the past week ....even considered doing it. but its fair to say its a love it or hate it thing.
however at least ya get anice set of decent modern headlights intothe bargin......
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
