  • Replies 50
Heeeeyyy Dats looking flash as eh. How long before you turn the key? So tell me the secret of the shiny rocker cover and don't just say elbow gease. Your secret will be safe with me, just post it here and I promise I won't tell a soul.
The secret of the rocker cover is... er.... ebay usa actually. I polished all the other parts though, like the timing cover and manifold with a wire brush, then sandpaper then autosol.
Have turned the key and the car runs a treat. Once it's run in Ill get a pro to look over it to make sure it's correctly timed and that I haven't misseed anything.
Hey,
These twits stock the pulley,
http://www.thezstore.com/page/TZS/CTGY/PEM06
but good luck with their defective online shopping cart, or getting them to answer emails. I got lucky and found mine on ebay USA for a little less as it turns out :thumbsup:
Word of warning though - these pulleys do not quite fit onto the key on the end of your crank. You'll need to file a smidge off the sides of the key to get the pulley to slide on without breaking the pulley, the crank, the oil slinger etc.]
Cheers, d
I bought my pistons from them. Plus 1.0mm forged flat top Ross Racing Pistons for a tad under $700.00 delivered. Compared to nearly $1600 here in Oz to get them made. Had no hang ups, deal went very smoothly.
Cheers, D
Actually, I have tried ordering from them again. This time I filled out both my mailing details and the billing details (it says that this isn't necessary if they are identical) and the cart was able to process my order. I'm still dirty on them for not replying to my polite email, but there's no denying they have some great stuff for L series engines.
  • 2 months later...
Changed to an electric fan on a thermo switch and tidied the last few things over the weekend. So that wraps up the engine build... until I have enough money for triples, and a stroker crank.
Now... time to paint the body.
That looks great man, very clean and tidy.
Am so tempted to give mine a good tidy up, but my wife will do unspeakable things to me if I head down that road again :P
Quick Q's: Did you make your strut brace, if so where did you get the turn buckle/adjuster from?
Cheers Dan
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
