hi guys a mate of mine just put me onto this site and wow!!!!!! it's like ebay but for japan and the best thing is it's interpreted. u have to sign up first to look through the list of stuff for sale but it only takes a few seconds. brake pads, fibre glass panels, lights and whatever. I even found an aftermarket bolt on gtr front end kit. i haven't ever brought anything from here so i dont know how it works but im sure u guys will love to have a look at it. http://www.importmonster.com.au/
i typed in wgc34 and had about 27 pages to look through.
https://www.sau.com.au/forums/topic/199282-massive-amounts-of-parts/
Sounds like a similar service to SlideWize (SAU sponsor)
http://www.slidewizeimports.com/
import monster just has flashier pictures on their website but that seems to be the only major difference.
I'd prefer to go with an sau sponsor but thats just me. :D
yeah, i cant seem to find a cost calculator of some sort. The site looks promising but i would really like to see shipping costs + all other fees calculated before i get addicted to bidding like i am on ebay :>
a friend of mine owns that site.
He's been importing for quiet a few years, under his other business Rampant Imports.
(and for those playing at home, slidewise used to (not sure if they still do) rent container space off my mate to import their parts! :D )
  • 3 weeks later...
Was doing a search on Google and this thread came up, thought I'd fill in some blanks :)
pixel8r - I can only assume you have not even signed up & checked out our site, otherwise you would see there's quite a bit of difference between our site and the other companies offering Yahoo purchasing services.
www.importmonster.com.au is not just a site advertising that we do Yahoo purchasing. The site is an entire Yahoo interface, acting as the 'middle man' between you and Yahoo. Our site translates into English, converts figures into AUD, allows you to estimate shipping & charges strips away all the non-auction related images, the additional links, the banner ads, etc.
Our site has the ability to search, have your own watch list (that is updated in real time), and you can place bids, on the spot, round the clock. You can even receive email updates the moment you win an auction, or get outbid.
The competition, get you to browse Yahoo yourself, and then send them a link manually telling them what you want. Too bad if it is 1:30am and the auction ends in 5 minutes :blush:
If you used the monster you could place your bid any time you like. :blink:
I'd prefer to go with an sau sponsor but thats just me. :)
Nothing wrong with supporting the people who support you - that is an admirable trait. We have already contacted the SAU hierarchy about advertising on your forums :)
looks very interesting, but how do you calculate the fee's ontop of the item cost? (e.g broker fee's, postage etc)
As ali-turko pointed out, there is an estimator on every auction page. Note that we only make money on our commission, that's it. All freight charges are charged to you at cost. Some companies charge you a commission, then inflate all the shipping costs, and pass on the bank fees (we wear those).
(and for those playing at home, slidewise used to (not sure if they still do) rent container space off my mate to import their parts! ;) )
If the competition uses us to provide their services anyway, we can't be too bad then :yes:
Although what we & others are offering is a 'Yahoo Purchasing Service' - nobody in the world has a site like ours :) A large amount of time and money has been invested into this project, and we're all pretty proud of it. :D There are already thousands of people using the site, we only launched it 6 weeks ago!
If you haven't had a suss, check it out, if I can help anybody out with searching for something just yell out :D
Daniel
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
