Hey guys, im a newby on here and i thought id share my car with you. its currently got the following specs
( as you can see in the pics its still an ongoing project)
rb25, stroked to 2.8
ported head ( friggin big ports)
1mm oversize stainless valves
big springs and titanium retainers
10.2mm 280 deg camshafts
semi dry sump
gt45r turbocharger on stainless manifold
4.5inch side exiting exhaust
custom plenum
custom one off full spool diff center
all speedflow lines
hybrid cooler ( soon to be dry ice)
1220cc injectors in modified rail
1/2 inch fuel supply and return
fuel lab regulator
dis-4 cdi ignition
haltech E11V2 ecu
dual 044 pumps off suge tank with tomei in tank lift pump
jatco 3n71b 3 speed,fully manualised, transbraked, kevlar bands, clutches, machined clutch drums with full needle rollers, pro rachet shifter
5500rpm stall convertor
fully welded 6 point cage
solid mounted engine trans and rear end
100mm single peice tailshaft
engine and trans cooler
pwr radiator
and many many more things iv forgotten about
before i go i wana say thanx to steve at steves speed shop at albion park rail, for all hes help with the speedflow setup, roll cage padding and fuel system. if it wasnt for him id still be stuck!! hes contactable on 42577333. tell him dan sent you and im sure hel look after you! :P
NOW what im curious to know, is there anyone on this site with around 400kw atws, and what times have you run? iv been told this setup will make a fair bit more than 400 kws, but i dont wana push my luck :(
iv been told by some people not to expect anythn better than an 11, but then other ppl tell me it will be a mid 9 car. someone please give me a "real world" estimate!!!!
Edited by 1TUF33
<br />what coils are you using?<br />
<br /><br /><br />
im currently using GM coils from a ecotec V6, but i have a set of MSD Coils here, setup for waste spark, virtually identical to the GM coils, but obviously higher output. I was quite supprised, as the MSD coils were only $270 for the set of 3 ( waste spark) and they are a direct fit into an ecotec.... if any holden drivers are reading......
<br />thats insane! <img src="style_emoticons/default/blink.gif" style="vertical-align:middle" emoid=":blink:" border="0" alt="blink.gif" /><br />
<br /><br /><br />
haha thanx bud. just wait til its finished and at powercruise this year!! ( hopefully)
myself and the boys from PDK performance are tuning it. we have had it tuned with the old ecu, no speedflow etc, and it made 800ish hp on avvy, 32psi peak, all the way up to 8500 then flattened rite off. its running 8.1:1 comp, and with the E11V2 i think we can see around 400-450rwkw without too much hassles.
( reason i sold my old ecu (microtech)was cos i was having a really bad run with work, lost my job and was without money. the first thing i was offered money for was my ecu LOL)
and im also looking at selling my engine soon to build a nice 26/30. if anyones interested lol
Edited by 1TUF33
pm me when your going to race ill be keen to come watch hopeful i should have mind back together in the next few weeks
r33 gtst
3l bottom
scatt rods
arias pistons
custom cams
ported 25head
comedic head gasket
arp head studs
custom intake
ebay exhaust mainfoild
custom cooler
550cc injector
was a gt3540r but now has 0.8 front cover 66 front wheel 1.06 rear
was a jatco but i smashed 6 all fully built transbrake the lot
now gtst box
triple clutch
car has already run a 10.4 at 130mph with standard rods/cams on 24psi
r33 gtst
3l bottom
scatt rods
arias pistons
custom cams
ported 25head
comedic head gasket
arp head studs
custom intake
custom cooler
550cc injector
now gtst box
triple clutch
So you changed from a jatco back to a 5 speed? hrmz..... interesting. how did the jatcos hold up? as in what times did you run with em and how long did they last?
Edited by 1TUF33
Awesome driveline, this thing will definitely be an animal down the strip.
BUT you have failed to mention anything about the most crucial components for all forms of racing: SUSPENSION setup. What have you done in this department? Even with the right components, it's going to take alot of fine tunning to get it all working properly.
9's are a definite possibility, provided you can get the car to hook up off the line.
Good Luck! and keep us posted on your progress.
Yeh well suspension.. im still using the tanabe street dampers that are in it atm, they handle well, but will be s$#t for locking the tires up. not sure how exactly im guna tackle that issue yet. i just want to concentrate on getting it in the power skids at powercruise for the time being lol
they normally lasted about 3months car ran the 10.4 with the jatco after 60foot it felt like i was going to get milk manual going to be more of a challenge
yes will definately be a challenge getting the gear changes right! at least it will make you work harder for you 10 sec passes haha. only reason i went auto was so i could spool up, otherwise i love manuals to death!
set of coil overs(if you need some let me know i sell them)amd m/t 28x9s will do the trick
use a two step to spool it up i hope to crack in to the high 9s with a bit of nos
you sell coilovers ay? well well... how much would a setup for me be? basically want the front to lift and the rear to squat am i correct? wat brand? what service life etc?
ksport coilover we are just finishing doing 90/10 insert so the front will lift hard but you dont want the back to soft call me on monday for price at A&B motorsports 99059523 ask for paul :worship:
Edited by craked
i will definately call about those coilovers man! got me very interested!!!!!
btw im contemplating running a 150 shot of gas to get the thing spooling qucker, so i dont hold the transbrake too long. you rekn this is an ok idea, or will it just burn clutches faster?
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
