Hey Guys,
I'll start off with Happy New Year! Everyone still recovering???
OK - so back to business... i've had my R33 S1 (but looks like an S2 so i guess its a 1.5 as some people here call it), for 1 year next month and have just started with the mods. So far i have a HKS spoung air filter with no box, Blitz BOV, 3'' turbo back exhaust system with high flow cat & FMIC. After this work was finished it got put on the Dyno and made 225rwkw - i dont have the sheet, he just called me when he did it and i fell off my chair at work when i heard it - does this sound right or should i get it done again or should i just take the results and run with it?
Anyways, so the next things i want done are: Electronic Boost Controller, Cool direct air intake for the air filter, PFC or some sort of aftermarket ECU, Z32 AFM. Once all that is done i suppose i would then need to change the clutch, fuel pump, maybe injectors?
I have read a lot of threads about doing up R33's and they are all from 2003/2004, so what i am asking is if anyone from experience thinks there is a certain order of which i should be doing the rest of my mods or if i have missed something that i need once i add a new part...?
I'm hoping to acheive over 300rwkw. Then i'll come show off with you guys at Dyno days other events... i'm yet to make my debut... lol :(
Thanks everyone!!!!
Sammy.
https://www.sau.com.au/forums/topic/199740-what-order-should-i-do-this-in/
sounds like a happy dyno. No way will a stock ecu make that much power. it is possible the ecu has been chipped in japan tho so could be worth while checking that out also.
Basically the minute you raise the boost with stock ecu you hit Rich and Retard which prevents you from making any real power at all.
to make 300 rwkw (your going to need stronger internals if you want it to last at this and over) you'll need
PFC
Bigger injectors
Bigger Fuel pump
Bigger turbo - 3076R with .83 housing comes to mind
z32 afm
and a good tune.
of course you'll need other support systems like clutch, fmic and turbo back exhaust...
There's not a chance you're on 225rwkw with those mods. Get it tuned somewhere where they know what there doing.
either they have no idea how to use a dyno or they are just trying to bullshit you.
i dont see why they would be trying to bullshit me... lol - who would do that?
i'll get it put on the dyno again to make sure - but that isnt why i wrote this thread, this is more to be focussed on the mods rather than the dyno results...
any other opinions on the mods guys? I jus want to make sure i do things in the right order because i dont want to add something then fark something else up along the way...
as the others have said 225rwkw is too high
190 to 200rwkw is about spot on
check what gear it was done in on the dyno sheet
might have been 3rd gear
or different diff gears in the back prehaps?
what rpm do you 100km/h at in 5th gear?
Guys!!!! lol - your all missing the point! hahaha - i will clarify the dyno results when i re-dyno next month...
i want to know what next - i need help to know which mods go after what i already have (FMIC, turbo back exhaust, air filter (no box), BOV)... in my 1st post i have listed some things that i think should go next but i dont know which order is the smartest way to go about it... please help with this???
do a search you will find everything you need
i did a search as i mention in my first post and i found a lot of good information but old information, i was just asking what people thought in their own opinion from experience what they found to be the smartest way to mod - what things to do 1st... i have already done the first stage of mods, its just the next step where one mod starts affecting other parts more heavily so i want to go about it the right way...
so if anyone is willing to help me with this, please do! lol
First, make sure it STOPS. Then make sure it HANDLES. Then make it go fast.
*well it has brakes... 60% / 50% - do you mean get like vented disks or whateva?
*handling is aweome!! no problems there... came with aftermarket apexi suspension
*now im trying to work on the power
well thats just the thing, you want 300 rwkw, so it doesnt matter which mod you do first as you will need to do ALL of the ones i listed in order to make that power.
if you dont want 300 rwkw and want to stick with the stock turbo, then i'd just get a PFC and an EBC and a damn good tune., will make good power and last ages, and both mods you can keep for future upgrade.
hope this helps, but you need to be clearer about what you want
OK well i want to keep the turbo stock for now... i want that to be like one of the last things to change as it will be one of the most expensive...
So if i get in order... EBC - Cool direct air intake - Z32 AFM - Fuel Pump & Injectors together. Then get the PFC last and have it all tuned? Reason why i said PFC last is so i dnt have to keep getting everything tuned after every mod... then ill change the clutch...
Then later somewhere down the track ill change the turbo... how does this plan sound?
sounds reasonable thats for sure, yes start getting all the parts now, so the AFM, injectors, fuel pump, ebc, and the PFC, get them all and then you can book it in with your tuner of choice to get all the parts installed and then tuned up. once you have all that you just add a turbo to make decent power.
as for cold air intake, you can do that any time, you wont need a retune for it.
OK sweet - i thought that for the cool air intake you would need it tuned because more air would be running through the POD filter...
Thanks for your help mate - i will start collecting the parts and get it all installed and tuned! Appreciate your opinion for this.
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
