  • Replies 40
to flush the radiator u dont neeed to remove it. just d/c the top hose and then the bottom hose. put a hose in the top and flush away. after that flush the engine by sticking the hose into the intake (top hose) and allowiing the watr to come out the bottom.
It will work better if you "reverse flush" the radiator. By adding water in the top, all you are doing is forcing the crap further into the cores.
Take it out, upend it and push water in the what is normally the bottom of the radiator.
hopefully have fixed my overheating probs will find out when i put the rad back in the car on the weekend . took my rad to work and sent it of to the guys that do our rads for our work . turns out it was about 40% blocked and the top tank wasent the best adding to that my thermostat was not working properly hardly operning in a boiling saucepan of water hopefully it's sorted .
on the other hand tonight my sons r33 looks like it has blown a hose behind the head somewhere will bring the pressure tester home from work tommorow and see what going on there .
this hot weather in adelaide is taking its toll atm . we have so many people phoning and driving off the street for aircon regass it's running us off our feet good for the boss i supose tho lol
and the funny thing is when its 30 degrees and i turn the a/c on after awile it overheats
if its 25 degrees outside i can turn the a/c on and it wont overheat
but when its 35 and over without a/c it overheats lol..............strangeeeeeee
not strange at all, the AC makes the motor work harder, the air con core in front of the radiator gets hot, and pases the hot air onto the radiator, theres extra heat under the bonnet... all taking its toll on the cooling system. If part of the cooling sys isnt working properly, then it all goes down hill.
well... well... the boys at thommo radiators found that my radiator was leaking pressure on the bottom of the seems
on order is a Just jap aloy radiator hopfuly there good i didnt want to spend 800 bucks for a genuine nissan one
Edited by Jsikalias
Yeah I've got one of those from fatz.. had two tiny pinprick leaks on the upper front corner (in the welds) which I wasn't very happy about but not much I could do, just put some silicon on them and she'll be right.
I am however having slight over heating problems under certain conditions now that I didn't have before, new thermostat, water pump and radiator cap on their way so I'll put those on before I make any claims about the radiator. Most others have good experiences so I hope that it's the water pump/thermostat/radiator cap that is the cause and haven't wasted money on the radiator.
whooo hoooo all fixed took it for a spin today up the hills with the aircon on it's another stinking hot day in adelaide and the needle sat a fraction just under half and did not move at all . cleaned out rad and new top tank . new thermostate . flush all old coolent out and replace with new total cost around 200 bucks . im as happy as a pig in poo .
found the problem in my sons car why his overheated it has split the turbo water line behind the head looks loke a prick to get at and fix .
bugga he can wait till the weather cools down lol mines fixed thats the main thing lol
cheers mid life crisis
Whereabouts would i be able to get a new radiator cap for my car? what specs or part no. should i be looking for? Cheers...
i think you would have to get a new cap from nissan i think thats where i would go just to be safe
hey atleast you knoe you have the correct cap then
    • Yeah agreed, you can't assume that shop are they only people who ever had to work on it. It was just a guess on the mods based on how things were done back then. You can check the Air Flow Meters by the part number on their tags, they are likely either Z32 or Nismo ones (both read about the same but the Z32 one is a little larger while nismo is stock size but supports the higher airflow like a Z32). And yes, all that would get you to 450hp / 340kw To tell what is happening with the turbos, you want a photo of the tag on the core, that will say what it was made out of  (they can retain the front and rear covers to make the plumbing easier)
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is juan@bardabe.com
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
    • shit boxes, kids, and daily drivers are all welcome
