Hi Guys,
I need to establish if a R34 has had the correct services especialy the 100k service.
I was hoping that someone would be kind enough to translate these service stickers.
Any help will be much appreciated, Mark.
https://www.sau.com.au/forums/topic/200024-service-tag-translation/
yeah, major service at 92, with timing belt done...
oil was changed at 115 in Jan last year
not sure wat 3rd sticker is all about
Thanks Beau,
I'll get some fresh oil and filters into her just in case as we don't have any history as only recently bought from dealer.
I've got a consult cable and datascan software on the way so will check for recent fault codes.
Glad to see that the 100k service is done as timing belts and bits can be time consuming and exy to do.
Thanks again, Mark :P
If it has recently been imported it would (should) have had oil, oil filter, air filter all replaced as part of compliance...
do you know when it was impoerted??
Thanks Beau,
Not sure when it was complianced but I do know a few guys that do or did compliancing and know that they don't always do all of the stuff that is required so better to assume that they have not been done recently.
Will get the filters and oil this weekend and have received the consult cable so will hook er up and see if there is any fault history.
Mark.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
