A friend's brother was putting a KKR on his r33 in his garage once. We bagged him so much about the turbo that he tried to smash his brother over his head with it, by the time he got the thing over his head his brother had him by the throat and it was all over.
hey man dont you drive a white r33, trian at a gym in caulfield and get the good stuff from garys on chappel street
  • Replies 97
limiter is set to 7500rpm im pretty sure, but since plenum upgrade and car hasnt been tuned, ive lost alot of down low and turbo comes on really hard bout 5000rpm and then goes straight to limiter...
Hi same problem have I have installed Greddy plenum and KKR 480 and tuboo boosts on 5000 to 7000 araund 17 PSI, is there any way to make it boosts up from down rpm??? and i still use stock catback if i will change it does it gives me any results?
Stock exhaust on a bigger turbo???????? are you nuts??????:P
Stock exhaust on a bigger turbo???????? are you nuts??????:D
yes i know:) its to hard to find here exhaust for R33 so i want to make it my self:) we have no dyno here I test it on Gtech and its shows 268 hp on wheel is that good for KKR480 on 16 PSI?
hey im running a 480 kkr and had the waste gate change and now i running 308 horse power at the rears with only something like 12 psi and before i got thw waste gate down is was up near 20 22 psi n thrying to pull paste the 400 horse power mark but as i havnt done the internals i had to lower it down again
[/quo
what rpm does your turbo spool up at?
  • 3 weeks later...
im sellin the kkr setup soon and im selling a real good Greaddy td06h-25H polished turbo with top mount mani and gready dump pipe, if u want this will spool fast n pull very hard all the way unlike the kkr that kickes in way too late on such high boost.. let me know if intersted
Hey
Was wondering if you still had the td06 top mount setup
and what price?
Please PM to let me know
Thanks
im running a kkr560 on my rb30 single cam motor, plenum, exhaust top mount manifold and i have the internal gate flap blocked off . its making 5psi at 2500rpm and 13psi at 3500rpm
i would run a external wastegate ;)
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
