Real Time Gps Gprs Gsm Car Tracker Alarm Tracking
do u have any for sale for the 295..
also curious how quick it sends u a message after the battery is dsconected.. meaning if u disconnect it for 5 seconds or less and put the power back on would it still sms u..? because i was thinkn u would b able to hook it up to a relay so when ya interiorlight comes on/door opens it will cut power ant send u an sms..
  • Replies 107
Posted Images
Yes, as mentioned before, you can use this method to trigger the alert. Once the main power gets disconnected for longer than 3 seconds, you will get the alert on your mobile phone. It usually takes around 5 to 8 seconds for you to get the alert from the time the main power is cut off.
Thanks gtr_z, my unit arrived about a week ago, I have just not had a chance to have a 'play' until now... actually got it about 4 or 5 days after paying via online transfer? Pretty quick!
Very impressed so far... comes with an active GPS antenna which even works accurately from inside my house (where other GPS's I've tested - bluetooth PC ones for instance - don't get a reliable signal).
A small caveat, FYI re: SIMs:
You need to disable the PIN code on your SIM, if you have set one whilst it was in a mobile phone, to use with the unit.
Great little device, should work nicely. My backup battery came to me charged and working too - switched it on right out of the box (after connecting antennas of course) :)
just read this for the first time, very interesting.
any idea if it consumes much power while the car is turned off?
as it is my cars battery starts goin a bit flat if i havent driven it for 2 weeks or so.
It doesn't consume anymore power than the average full alarm system.
  • 3 weeks later...
does anyone know if this has no GPS signal and you SMS it to ask it where it is, will it give you the last known GPS co-ordinate? i read in the details at the top that it will give you the GSM location but this is kinda useless if your in a big city and your car has been stolen and is in some garage somewhere, it would be good if it gave you the last known location then it would make it alot easier to locate?
also how long does the backup battery last for if power is cut to the unit?
Edited by R33_Cam
The manufacturer claims the back-up battery will last for 48 hours if the main power to the unit is cut. I have never tested it myself, I can't really say for sure if it's accurate. The unit will alert you after 3 seconds if the main power is cut or if your battery dies anyway. The unit still works (all GPS, GSM & GPRS) even though it's well hidden in my car inside my full-brick lock-up garage.
Edited by gtr_z
Hi mate, just wondering if you know if this will work with nokia N82/95/96 maps?
It should if you can enter the GPS coordinates manually on those phones the same way as you do on online maps such as Google Maps/Earth. You may want to check if your phone has this 'manual-entry' function.
Edited by gtr_z
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
