Real Time Gps Gprs Gsm Car Tracker Alarm Tracking
do u have any for sale for the 295..
also curious how quick it sends u a message after the battery is dsconected.. meaning if u disconnect it for 5 seconds or less and put the power back on would it still sms u..? because i was thinkn u would b able to hook it up to a relay so when ya interiorlight comes on/door opens it will cut power ant send u an sms..
  • Replies 107
Posted Images
Yes, as mentioned before, you can use this method to trigger the alert. Once the main power gets disconnected for longer than 3 seconds, you will get the alert on your mobile phone. It usually takes around 5 to 8 seconds for you to get the alert from the time the main power is cut off.
Thanks gtr_z, my unit arrived about a week ago, I have just not had a chance to have a 'play' until now... actually got it about 4 or 5 days after paying via online transfer? Pretty quick!
Very impressed so far... comes with an active GPS antenna which even works accurately from inside my house (where other GPS's I've tested - bluetooth PC ones for instance - don't get a reliable signal).
A small caveat, FYI re: SIMs:
You need to disable the PIN code on your SIM, if you have set one whilst it was in a mobile phone, to use with the unit.
Great little device, should work nicely. My backup battery came to me charged and working too - switched it on right out of the box (after connecting antennas of course) :)
just read this for the first time, very interesting.
any idea if it consumes much power while the car is turned off?
as it is my cars battery starts goin a bit flat if i havent driven it for 2 weeks or so.
It doesn't consume anymore power than the average full alarm system.
  • 3 weeks later...
does anyone know if this has no GPS signal and you SMS it to ask it where it is, will it give you the last known GPS co-ordinate? i read in the details at the top that it will give you the GSM location but this is kinda useless if your in a big city and your car has been stolen and is in some garage somewhere, it would be good if it gave you the last known location then it would make it alot easier to locate?
also how long does the backup battery last for if power is cut to the unit?
Edited by R33_Cam
The manufacturer claims the back-up battery will last for 48 hours if the main power to the unit is cut. I have never tested it myself, I can't really say for sure if it's accurate. The unit will alert you after 3 seconds if the main power is cut or if your battery dies anyway. The unit still works (all GPS, GSM & GPRS) even though it's well hidden in my car inside my full-brick lock-up garage.
Edited by gtr_z
Hi mate, just wondering if you know if this will work with nokia N82/95/96 maps?
It should if you can enter the GPS coordinates manually on those phones the same way as you do on online maps such as Google Maps/Earth. You may want to check if your phone has this 'manual-entry' function.
Edited by gtr_z
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
